Old 06-23-2014, 09:44 AM   #1
62lwbc10
55 first series on a 1997 C5 chassis....
Hello All, A buddy of mine has a decent 1955 first series 5-window short step that he intends to put on 1997 C5 corvette chassis and powertrain. Has anyone on this forum ever done anything like this? Just looking to see if I can gain any insights for him from the experience on this board.
Thanks alot,
MArk
62lwbc10 is offline   Reply With Quote
Old 06-23-2014, 10:49 AM   #2
Hogger54
Hogger54's Avatar
Re: 55 first series on a 1997 C5 chassis....
This is pretty close. http://67-72chevytrucks.com/vboard/s...d.php?t=631911
Hogger54 is offline   Reply With Quote
Old 06-23-2014, 11:11 AM   #3
Dan in Pasadena
Dan in Pasadena's Avatar
Always heard C4 works but C5 is too wide. Maybe with a lot of negative offset on the rims it'll work though actually using the Vette chassis instead of using components to adapt the Vette IFS & IRS to the truck's original frame will be an interesting challenge.
Watching.....
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 06-24-2014, 09:17 AM   #4
OneOffStroker
I was going to do this, but decided to save several thousand dollars and go with a Jag IFS & IRS instead.
The best part of the C5 vs. the C4 is that the C5 uses a transaxle and torque tube, so 80% of your frame is already made for you. The C5 wheelbase is shorter, so you will have to move the fromt suspension cradle forward a few inches, which means new motor mounts and will also need firewall offset because the motor can't just be slid forward because of the torque tube design. There is a TON of fab work, but it would be pretty neat to have done in the end.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
