Old 06-23-2014, 11:56 AM   #1
71enthusiast
71enthusiast's Avatar
No Seal Window Sweeps
This is a little write up about my experience with window sweeps.
I have bought these things from different companies and still end up with the same results.
Here is the problem I am having:
I'm looking for a set that actually seal when the window shuts.
All the ones I've used haven't even came close.
This picture is of a brand new door also so there shouldn't be any seperation.
I've used GMCPauls and Classic Industries which both have top quality parts, However this seems to be a problem with me.
If anyone knows where to find some extra thick sweeps, let me know!
71enthusiast is offline   Reply With Quote
Old 06-23-2014, 12:11 PM   #2
jabborabbo
jabborabbo's Avatar
Re: No Seal Window Sweeps
I think that they only seal when the window is rolled all the way up...they catch on a bar that sticks out from the window....
jabborabbo is offline   Reply With Quote
Old 06-23-2014, 12:19 PM   #3
71enthusiast
Mine dont seal with the window rolled up either. There is still a gap between the window bracket and seal.
Old 06-23-2014, 12:55 PM   #4
Lee H
Lee H's Avatar
I checked mine, yours measures .50. mines .0395 (precision brand) and seals with window up or down. What is the total gap between the metal to metal door? How is the felt in the window runs?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 06-23-2014, 01:27 PM   #5
leftybass209
leftybass209's Avatar
Have you measured your "New" door gap to an original?
leftybass209 is offline   Reply With Quote
Old 06-23-2014, 01:41 PM   #6
AirSpeed
AirSpeed's Avatar
I have the same problem, there's about a 1/8th" gap. I saw some wide trim awhile back but can't remember where. I do know that the new trim I put in was narrower than the little chunk of original trim that was still hanging on by a thread before I tore it out
AirSpeed is offline   Reply With Quote
Old 06-23-2014, 01:41 PM   #7
71enthusiast
Alright I measured metal to metal opening.
I am not within reach of a micrometer, but with a measuring tape both doors measured at 1 & 1/16" inch.
The felts and rubbers are both new
Old 06-23-2014, 01:50 PM   #8
Lee H
Lee H's Avatar
Mine are .89
Old 06-23-2014, 03:04 PM   #9
leddzepp
Moderator
leddzepp's Avatar
I've used Precision and they fit very well. I've also used Re-Pops brand and could barely roll the window up or down as they were very tight. The problem may be your door gap and not the seals.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 06-23-2014, 03:09 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
Just because your door is new doesn't mean it is made correctly. It looks to me like the opening is too wide.
I agree with lefty double check it.....
If you want the VERY best window seals make sure the vendor sells the "Original" "Repops" brand window seals. Made in the USA. Read this thread:
http://67-72chevytrucks.com/vboard//...d.php?t=493227
Read the whole thread, but be sure and pay special attention to Post #19 by Tim....
LockDoc
Leon
Old 06-23-2014, 05:02 PM   #11
71enthusiast
Thanks Guys for the help!
And LockDoc I wasn't able to open that link you gave me
Old 06-23-2014, 05:35 PM   #12
LockDoc
LockDoc's Avatar
Try it now. I re-did it....
LockDoc
Leon
Old 06-24-2014, 09:58 AM   #13
TheOtherScott
LockDoc
Regarding the thread you recommended, do you have a photo or diagram showing the strap connecting the inner/outer door skins referred to in post #23 by GMCPAUL?
TheOtherScott is offline   Reply With Quote
Old 06-24-2014, 12:22 PM   #14
DUD2STUD
DUD2STUD's Avatar
Just like Leddzepp said I use re-pop brand and mine are tight to the point it's hard to roll the window up and down. I'm hoping the will break in a little but there is no water getting in for sure.
DUD2STUD is offline   Reply With Quote
Old 06-24-2014, 10:57 PM   #15
LockDoc
LockDoc's Avatar
No I don't. I know there are some pictures on here but I can't seem to find them. I will try to remember to take a couple tomorrow....
LockDoc
Leon
Old 06-24-2014, 11:00 PM   #16
TheOtherScott
LockDoc
Whenever you have time, it will be much appreciated!
Old 06-26-2014, 07:58 PM   #17
LockDoc
LockDoc's Avatar
I am posting the pictures of the door strap/connector in a new thread. Here is a link to it...
http://67-72chevytrucks.com/vboard/s...d.php?t=633866
LockDoc
Leon
