Old 06-23-2014, 02:29 PM   #1
DreamRyder1963
DreamRyder1963's Avatar
Differential Filler Help Needed
The filler plug on my differential is shot. The head is rounded off and the plug is stuck. Unfortunately I drained the fluid and replaced the gasket before I checked the plug. If I pour the fluid down the vent tube, which is clear as far as I can tell, will it fill the diff? This will only be a temporary solution until I can get a cover with a fill plug, but I need my truck running tomorrow.
1971 Chevy C10 Cheyenne (sold for Mazda)
1963 Chevy Corvair Pro-Touring Project
2012 Mazda 3 i Sport sedan
http://www.dracoautodesigns.com/
DreamRyder1963 is offline   Reply With Quote
Old 06-23-2014, 03:59 PM   #2
Fitz
Re: Differential Filler Help Needed
I would go and get a new cover right now! If you over fill it, the diff will just puke lube all over your driveway but if it is under filled you will need to get it overhauled...that's big bucks vs the $40.00 or so a new cover will cost.
Fitz is offline   Reply With Quote
Old 06-23-2014, 04:04 PM   #3
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
If you have a welder, get a big nut that will fit over the plug and weld the top of the nut to the plug then you can get a wrench on it and it should come out.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 06-23-2014, 04:10 PM   #4
Wrenchbender Ret
Have you tried a hammer & chisel. I have gotten them off that way. If you keep catching the edge & hammer at it it eventually turns. If you get the flange completely broke off it usually comes on out.
Wrenchbender Ret is offline   Reply With Quote
Old 06-23-2014, 04:30 PM   #5
DreamRyder1963
I have called all of the local auto stores and no one has one with a cover with fill tube, and they cost way more than $40 if they have one. I have tried lots of heat and lube I will try the chisel.
