68 C 10
![]() Join Date: Aug 2010
Porterbuilt lower arms
I put some 15 inch rallies on yesterday to check the frame with some weight on it and the PB 1 inch forward arms (lower) are rubbing the wheels IT was my understanding that these would clear these rims unlike factory a arms without some mods being done. I have the classic modular 2 inch drop spindals 2 1/2 inch drop spring
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
68 C 10
Re: Porterbuilt lower arms
67-72 parts collector,…
![]() Join Date: Nov 2002
I think your CPP Modular spindle is the issue.
It narrows the track width compared to a standard drop spindle. (still don't know how much,... but that's another story)
68 C 10
Between this and my tie rod issues these spindals mAy get the damn boot about to pull my hair out
Which spindals you think I should try I'm ready
Sounds like I have almost the same setup. PB 1" fwd control arms and CPP modular spindals with 2" dropped springs. But I am running 15" x 6" steel wheels with roughly 3.5" back space and they clear with about 1/2" of clearance.
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers Last edited by nds1968; 06-23-2014 at 06:09 PM. |
#6 | |
Try to find a set of stock steel wheels for rollers. (or mount them backwards if you just want wheels on it). Have you talked to Nate. I'm wondering if you got narrowed and forward a-arms by mistake.
All the Dropmember guys have to trim the length of the steering rack threads for the Dropmember's narrower track width.
Cutting the tie rod end would be easier for your situation. I would talk to Nate first.
#8 | |
68 C 10
I've emailed PB and left a voice mail just waiting on a return. But I see regular spindals in my further I have a set of 20's but want to be able to put some 15's on in case I need to get it home. But will wait to confirm a arms with Nate. I'll get the new spindals then my tie rods will be to short haha my luck.
#9 | |
Don't get discouraged! Sometimes the joy found in building a classic truck comes after all the headache and frustration. You are not the first guy to tackle this swap, so I am sure we can help get it all figured out. If you don't hear back by the end of the day, please send an email to my personal account so I can make sure to follow up: nate@pbfab.com Thanks!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
