Old 06-23-2014, 07:06 PM   #1
tjsblazer
tjsblazer's Avatar
Question Factory hangers for Dual Exhaust?
Hi, wondering if there are factory hangers available for installing Dual exhaust on a 4wd Blazer. Has anyone used something, even if off another period correct truck. Thanks for any help.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 06-24-2014, 12:04 AM   #2
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: Factory hangers for Dual Exhaust?
On most 4x4 Blazers, on the drivers side, there is two brackets that hold single exhaust pipe for stock application. Mounted on frame, one by trans/t-case and one hanging from crossmember over rear axle. I acquired another set from a board member and hung the rear opposite the other. The one mounted to frame, I modified it so the brake, fuel lines could pass between it and frame. Bent to fit 2.5 pipe all the way back with down turns.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 06-24-2014, 12:09 AM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I also did the same - all K5s left GM with single exhaust but also with holes already on the opposite frame rail for another 4wd front exhaust hanger. There are pics buried in my K20 build thread linked in signature below.
Old 06-24-2014, 10:51 PM   #4
tjsblazer
tjsblazer's Avatar
Thanks guys. Time to post a WTB ad. Are these Blazer only parts or Truck also?
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 06-24-2014, 10:54 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks guys. Time to post a WTB add. Are these Blazer only parts or truck also?
Any 4wd - pickup or K5, 1/2t or 3/4t should have same but not sure if differ between 8 and 6 cylinder
Old 06-24-2014, 10:57 PM   #6
tjsblazer
tjsblazer's Avatar
Thanks, I'll post in the Truck forum for more eyes.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
