PS out again
I replaced the PS pump about 300 miles ago. I bought one at NAPA. It had a life time warranty on it. Well I will be replacing it tomorrow. I have had it with bad rebuilt parts. It will take me 4 to 5 hours to do the job. I may wind up selling the truck.
Re: PS out again
Don't sell the truck over bad parts man!! I know how it feels where you get really pissed off at the truck or something cause you have to replace parts yet again. Hopefully the next one of the pumps is better! Its an old truck remember.
Re: PS out again
Rebuilt parts do suck. I hope your not serious about selling. Relax. Fix your truck and when your driving again you will remember why you have an awesome truck that no one else has.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
![]() Join Date: Apr 2011
Re: PS out again
Don't let that influence your decission to get rid of the truck. Bad parts are a fact of life. Does it suck...you bet it does but, I bet you'd be kicking yourself if you sold it.
Re: PS out again
Bad parts suck! Put a full bottle of Lucas power steering conditioner in this time. It's thick stuff and has always helped keep my older steering parts alive. Also, there's a brand called Lares and they rebuild quality parts in the USA and the prices are very low. Look them up.
![]() Join Date: Mar 2011
Re: PS out again
You can rebuild them yourself. If you have a decent core, the parts are less than $20 to do it and there's videos on youtube that go step by step. It's real easy and then you know what's been done to it. Good luck and don't give up.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
Re: PS out again
Once had a mechanic tell us " new means new, it doesn't mean good!"
What is going wrong with them? Seen a lot of people keep replacing pumps when there was a problem with the box itself. Strongly recommend flushing the system before installing the next pump, on the off chance there is some debris in the system causing repeated failure. Defective parts are disgusting, I agree, but afterall- no one is perfect, have to except that "things" happen in even mass production. |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: PS out again
I would head to the wrecking yard, find the one like what you have, clean it up, install it and put the PS conditioner in there. You can surely bet, the reason that vehicle is in the wrecking yard has nothing to do with any PS issues. I bet you could get out for under $20.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: PS out again
Here is the pump that I am replacing. It was leaking around the part that the cap goes into. At the bottom of the long part. The other pump that I got to put on is also bad. The housing is blocking the bolt that goes into it. The top bolt will go in but the bottom one wont go in. So now I have to take that one back. This may be a 40 hour job.
Re: PS out again
I'm telling you return that pump outright. I like the junkyard idea plus conditioner. Or just get the Lares pump and know its a USA reman. My steering box from them was beautiful. Junkyard is probably best though - cheapest and most likely a good pump.
Re: PS out again
Do you have Lares web site?
Re: PS out again
#13 | |
Re: PS out again
Takes about as long to do as it did to type it up. |
#14 |
Re: PS out again
http://www.larescorp.com
I don't have a pump from them but if they rebuild pumps like they rebuild steering boxes you should be really happy. Plus the prices are less or about the same as part store rebuilds. I hope the pumps are as good as the boxes though. |
#15 |
Re: PS out again
If you care about originality and getting the correct style reservoir, it can be tough because most are the later "triangle" reservoir (which i never usually have leaks with) or the "tube" style reservoir. It took me 4 pumps to find the correct reservoir, all the cardones, etc are coming back as different reservoirs. You can swap them, but whatever, i paid for a whole pump and i want that. If you don't care, look for one with the later reservoir, i have less issues with those leaking. Atsco had the correct reservoir.
Project "i'm just going to clean up the interior and the engine bay": http://67-72chevytrucks.com/vboard/s...d.php?t=550931 |
#16 | |
Re: PS out again
#17 | |
Re: PS out again
| Bookmarks |
