![]() Join Date: Mar 2014
Leaky axle
Re: Leaky axle
![]() Join Date: Mar 2003
Re: Leaky axle
Dana 44. You'll need wheel bearing seals? and inner oil seals at the minimum. You'll have to pull the axle shafts out and the carrier. Who knows, maybe u-joints and ball joints also.
Re: Leaky axle
so its a Dana 44? Learned something. thanks
![]() Join Date: Aug 2008
Re: Leaky axle
May as well freshen the whole thing up with new seals, gaskets, u-joints, etc. when you have it apart. Inspect the wheel hub bearings and if they have fretting or score marks then swap those too.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
Re: Leaky axle
It's a bigger job than you might think.
I went ahead and did my ball joints, axle u-joints, all the seals and decided to put a front locker in while it was all apart.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
Re: Leaky axle
Does this look about right, am I missing anything?
1971 CHEVROLET BLAZER 5.7L 350cid V8 MOOG/PRECISION 365 Universal Joint RAYBESTOS 5051156 (505-1156) Ball Joint RAYBESTOS 5001070 (500-1070) Ball Joint TIMKEN SET37 Wheel Bearing TIMKEN SET45 Wheel Bearing TIMKEN 442380 Wheel Seal TIMKEN 5131 Axle Shaft Seal |
#8 | |
Re: Leaky axle
Re: Leaky axle
I rebuilt mine about 1 year ago on my 71. The problem I had was with the castle nut that is used to adjust the lower ball joint. I did not have the correct socket to adjust it. now I think it would have been better not to have replaced them and left the originals castle nuts in place. I took several time to get the ball joints correct.
Re: Leaky axle
DWilbur is describing this special socket used to torque the upper ball joint seat.
Re: Leaky axle
do you have any pictures of what this tool adjusts, because I am not seeing it on my truck.
thanks for the help all! |
Re: Leaky axle
If you unthread the castle nut from the upper ball joint you will see this beneath it. There is a threaded tapered sleeve that threads into the top of the axle C to set the upper ball joint and set a little preload.
#13 |
Re: Leaky axle
Thanks, I will check it out.
#14 |
Re: Leaky axle
I worked on this over the past couple days and found that I needed a new axle slinger on the driver’s side and this is what lead to the seal failure. Also the inner lock nut on the passenger side was missing it pin that locks in to the retaining ring so had to order a new lock nut. All in all I replaced both axle seals wheel and spindle seals and bearings u-joints and upper and lower ball joints. The tool rental for pressing out the ball joints was $200, ouch, but you get it back it just ties up your funds.
Waiting on the axle slinger and the lock nut to come in and I will be putting it all back together next week. |
#15 |
Re: Leaky axle
#16 |
Re: Leaky axle
Got my new axle slinger in . Here it the new one next to the bad.
![]() I also ran into a little problem. When I took all the front end components off, I was able to get this off but failed to put it back on in the same order and now as you can see I don't have clearance to install. Please tell me there is a trick to getting this back on without taking the hubs off again! ![]() ![]() |
#17 | |
Re: Leaky axle
I have done this before. If your TRE's have not been off in a while, it can be tuff.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
#18 |
Re: Leaky axle
I agree with oldchev4x4.
Heat and lube are your friends.
#19 |
Re: Leaky axle
Truck in finally back together, I loosened the leaf spring U-bolts and jacked it up just enough to get the steering arm back in, now on to other items that need attention.
