Old 06-23-2014, 11:08 PM   #1
Doobie1
69 gmc ls3\ t56
hi,
i am in need of info, i am trying to install a engine from a 10 camaro LS3 but
the engine was purchased with no accessories, will all the front accessories
from a truck based ls engine work on the camaro 6.2?
thanks sean
Doobie1 is offline   Reply With Quote
Old 06-24-2014, 08:16 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: 69 gmc ls3\ t56
Originally Posted by Doobie1 View Post
hi,
thanks sean
The 2010+ Camaro has the same offset as the truck, so yes they will bolt on.
Hart_Rod is offline   Reply With Quote
Old 06-24-2014, 10:46 PM   #3
solidaxel
solidaxel's Avatar
Re: 69 gmc ls3\ t56
Is your truck getting a little up grade!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-24-2014, 11:26 PM   #4
Doobie1
Re: 69 gmc ls3\ t56
Thank you f or the reply,
So, any 2010+ truck with any of the 4.8, 5.3,6.0 or 6.2 will work? I need all acc
brackets, alt power steering pump, starter, >>>>> ha ha yeah its getting a lil power upgrade......, sean
Old 06-25-2014, 12:28 PM   #5
dayj1
Re: 69 gmc ls3\ t56
The truck PS pump/alternator bracket will contact the Camaro L99 waterpump and Camaro throttle body. You can get around that by relocating the idler on the bracket and trimming the bracket. Just FYI that it's not quite a bolt-on.
dayj1 is offline   Reply With Quote
