Old 06-23-2014, 11:14 PM   #1
'65 chevy lover
Will my stock cross member work?
I'm going to go with a TH 350 trans in my '65 chevy PU. I've got a stroker 383 coming from Engine factory to go in front of it. The trans that was in it was a 2 speed power glide. Will the stock trans cross member with the stock E-brake setup work with this trans? I realize I may need to move it forwards or backwards to work but, my main concern is, will the TH 350 work with the stock cross member with the stock E-brake? Thanks in advance for any help.
'65 chevy lover is offline   Reply With Quote
Old 06-24-2014, 12:04 AM   #2
pdxhall
pdxhall's Avatar
Re: Will my stock cross member work?
It will work just fine.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 06-24-2014, 11:51 AM   #3
'65 chevy lover
I won't have to move it front or back and, the stock E-brake will not have to be modified? It's the setup that has the e-brake mounted on top of the crossmember. Just wanted to make sure. Thanks for your help.
Old 06-24-2014, 12:41 PM   #4
1963c-10
1963c-10's Avatar
If this is what you have? If so, yes, it will work with the powerglide, th350 and th400. I'm sure the 200r4 and 700r4 will work also.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-24-2014, 12:49 PM   #5
'65 chevy lover
Yes, that is what I have. Thanks for the info!
Old 06-24-2014, 12:51 PM   #6
1963c-10
1963c-10's Avatar
No problem
