Old 06-24-2014, 02:44 PM   #1
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
20x15 wheel
Can a 20x15 wheel fit under a coil spring truck with simply a tub? or is other modification needed? the rear is dropped 6in with a drop coil. I plan on ordering a custom offset so I should be able to get the wheel centered where I want it... just concerned about it rubbing on the coil or bump stop bracket... if I go 20x15 wheel I would be wrapping it in the M/T Sportsman S/R, LT 29 x 18R20. Height is dead on what I am looking for.
Thanks in advance...
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 06-24-2014, 07:23 PM   #2
Pro Performance
Pro Performance's Avatar
Re: 20x15 wheel
You should be Ok with the 15" wheels with just the sheet metal work, and no frame mods. It will come close, but will have enough clearance. Here you can see a 14" wide wheel with a PB onboard bag setup, and it would barely have room if there was a coil spring sticking outside the frame some in front. You would have to move the wheel as far outside as possible.
Measuring is always best when trying to squeeze the maximum in there. Do they offer a narrower tire than an 18" wide? Maybe a 16"?
Pro Performance is offline   Reply With Quote
Old 06-24-2014, 10:12 PM   #3
Hart_Rod
Hart_Rod's Avatar
Re: 20x15 wheel
What size and brand are the rear tires?
Hart_Rod is offline   Reply With Quote
Old 06-24-2014, 10:26 PM   #4
rwade
rwade's Avatar
Re: 20x15 wheel
I can't swear rob, but they look like 405/25/24's. definitely Pirelli tire tread
Wade
rwade is offline   Reply With Quote
Old 06-24-2014, 10:43 PM   #5
Pro Performance
Re: 20x15 wheel
It has to be that 405/25/24.... I agree.
Old 06-25-2014, 08:39 AM   #6
chevyguy_72
Vintage Evil
Re: 20x15 wheel
Yeah loving those rear tires... would hate to see the price tag... Pirelli doesn't appear to be making them anymore or they are just starting... cant really find any to buy except Ebay and Pirelli doesn't list on their site...
as far as M/T they offer:
Tire: 29X15.00R20LT Rim width: 13.0-14.0
Tire: 29X18.00R20LT Rim width: 15.0-16.0
They do have the 15in wide tire but then it drops down to a 13-14 rim width which I am having trouble locating... Intro, Billet spec, etc tends to jump from 12-15 with nothing in between...
Current Rides:
Old 06-25-2014, 09:03 AM   #7
rwade
rwade's Avatar
Re: 20x15 wheel
As far as Pirelli not making them, been hearing that for last few years. I think there are way too many people running those for them to stop. What I have heard is they make a "run" of them for the year at a certain time and supply gets low before the next run. Maybe give them a call to confirm that if your seriously considering them, that's what I did 2 years ago.
Wade
Old 06-25-2014, 09:05 AM   #8
Hart_Rod
Hart_Rod's Avatar
Re: 20x15 wheel
Did you narrow your rear end? I have a 7" backspacing on a 20x12 with a factory 68 rear and I'm running 31x16 20 M/T SRs on my 20x12 rims and they fit fine. The problem I'm having is MT quit making the 31x16s and I'm not sure what I'm going to replace these with. I don't want to step down to a 29" tall tire or go to a narrower tire. So I'm not sure what my options are going to be....
Old 06-25-2014, 09:55 AM   #9
Pro Performance
Re: 20x15 wheel
Intro and some of the others will make any width you want, and just becomes a non-standard width. Instead of them being able to buy the outer, they have to create by narrowing a wider one down. For a 14" wheel, they will narrow down a 15" outer.
The tires are available and can get them for you. I have gotten them in the past for customers. I have heard the same thing about not being available, but never had an issue getting them so far. Pricing for tires changes constantly, and last time I checked, they were $470 a piece.
Old 06-25-2014, 10:30 AM   #10
chevyguy_72
Vintage Evil
Re: 20x15 wheel
Similar setup as you... stock width 67 rearend... I haven't had much luck finding other tires that will work for the rear in 20s... Either the M/T options (29x18 or 29x15) or you jump down to a 315/35/20 which is 12in wide and 29tall (toyo makes this one but other brands might as well) or you can go to a car tire but I have been told those might not hold up so well to the weight of the truck as they were designed for light weight vettes and exotics...
$470/ piece for the 24in rears? that's not bad... about the same at the M\T but the 24in wheel that can handle it would prob be much more $$$$
As far as custom widths from intro etc what kind of money does it add to have them make a 13/14 inch wheel... I am a little concerned over this process as on the Camaro forum there were companies doing custom width wheels that were not cheap and they were having horrible balancing etc issues with them... then the company wouldnt stand behind them so guys were stuck with $5k worth of paperweights (Not saying that would be the case here... just explaining weariness)
Current Rides:
Old 06-25-2014, 11:14 AM   #11
rwade
rwade's Avatar
Re: 20x15 wheel
I've got a 14" wide Raceline and no issues balancing. My set of 24X9 & 24X14 were about $3300-$3400 delivered, if I remember correctly. About a grand less than intros (and I've had them too, & loved them)
Wade
Old 06-25-2014, 11:26 AM   #12
Hart_Rod
Hart_Rod's Avatar
Re: 20x15 wheel
Wade
With tires?
Old 06-25-2014, 11:58 AM   #13
chevyguy_72
Vintage Evil
Re: 20x15 wheel
which racelines do you have? more pics somewhere?
and wondering the same as rob... which tires and sizes you running?
Pirellis we discussed further up the thread?
Wade
Current Rides:
Old 06-25-2014, 12:05 PM   #14
rwade
rwade's Avatar
Re: 20x15 wheel
I am running the 405/25/24 & 255/30/24 on mine with Raceline Speedster 5
Old 06-25-2014, 06:09 PM   #15
chevyguy_72
Vintage Evil
Re: 20x15 wheel
Very nice...
Assuming your rearend is narrowed?
Current Rides:
Old 06-25-2014, 07:04 PM   #16
rwade
rwade's Avatar
Re: 20x15 wheel
Yes, 11" total.
Wade
Old 06-25-2014, 07:46 PM   #17
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 20x15 wheel
With the exception of brake clearance, you all are making me glad I only run a 15" rim. I really like only paying $150/e for MTs on my 15x12's
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-25-2014, 07:55 PM   #18
rwade
rwade's Avatar
Re: 20x15 wheel
Yeah, they are a little more than that. What size tire you running on that 15x12?
Wade
Old 06-26-2014, 09:40 AM   #19
chevyguy_72
Vintage Evil
Re: 20x15 wheel
Yes, 11" total.
Wade
what rear suspension you running?
Current Rides:
Old 06-26-2014, 10:52 AM   #20
rwade
rwade's Avatar
Re: 20x15 wheel
Modified factory trail arms, bags in front of axle, with Porterbuilt weld in notch, I set it up to where it's about in the middle of the "extreme" and "mild" notches they sell.
Wade
Old 06-26-2014, 10:56 AM   #21
Bhelton
Bhelton's Avatar
Re: 20x15 wheel
You gotta stop posting pics of this beast, it makes me want it! Lol
Bhelton is offline   Reply With Quote
Old 06-26-2014, 12:31 PM   #22
rwade
rwade's Avatar
Re: 20x15 wheel
Thanks Ben, I'm close to getting it running again, then I'll be able to get some updated pics. Also picked up a 69 SWB gmc about 2 weeks ago, kind of a driver, but oh the possibilities.
Wade
Old 06-26-2014, 12:52 PM   #23
chevyguy_72
Vintage Evil
Re: 20x15 wheel
Wade
Where do you even find truck that look like that?
Everything I look at is a mess....
Current Rides:
Old 06-26-2014, 02:03 PM   #24
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 20x15 wheel
Wade
325/50/15 MT DOT. Could actually go a little bigger. Stock width 12 bolt, custom beadlocks.
Old 06-26-2014, 02:10 PM   #25
rwade
rwade's Avatar
Re: 20x15 wheel
Found the gmc on Craigslist. Sometimes good stuff pops up. Original 307/turbo 400, posi trac.
Post some pics of the 325/50/15 I'd love to see how they look on your truck
Wade
