Old 06-24-2014, 03:56 PM   #1
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Vacuum gauge woes...
I am trying to attach a stock vacuum gauge to my inline 6 on my 68 C10. I have seen pictures on here, but they confuse me since some hose ends are not shown. Can someone clear this up with pictures that show where EVERY hose and attachment go?
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 06-24-2014, 04:05 PM   #2
davepl
davepl's Avatar
Re: Vacuum gauge woes...
You'll never get it perfect because so far as I know a C10 couldn't have a vacuum gauge. You needed to be in the medium duty (C40+) to get them, I think.
So, even if we can document it someone will have to chime in as to whether the C40+ firewall holes are the same as C10-C30.
I haven't connected mine yet either. If I wind up with a spare firewall hole or room in an existing grommet I'll do that, otherwise likely T off the line coming in for HVAC under the dash.
Page 191 of the assembly manual shows the engine vacuum line config for the L6.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-24-2014, 04:49 PM   #3
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
If your truck is an automatic then there should be a vacuum fitting on your engine somewhere with a line going to the trans for the modulator. I'd use that port for your vacuum line but you will probably have to get a double tree vacuum fitting for the engine. In the firewall notch and just towards the drivers side of the truck there is a rubber grommet in the firewall that some wires and your oil pressure gauge line go through and then to your gauge pod . I'd use that grommet to run the line from your vacuum source to the gauge. Hope this info helps and unfortunatly I do not have any pictures..
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-24-2014, 06:32 PM   #4
HIGHWAY BY THE SEA
Mine is manual transmission (for now). I thought all I had to do was "T" into the hose that connects to the top of the valve cover and goes to the "nozzle" on the space between the carb and valve area. But the pictures I have seen do not appear to depict that as the correct way. I just got my TEMP and BATTERY gauges working today, and I hope to have the OIL and VAC ones done by tomorrow.
Old 06-24-2014, 06:46 PM   #5
Already Gone
Sorry not at all familiar with the 6 cyl engines.
Old 06-25-2014, 11:53 AM   #6
HIGHWAY BY THE SEA
Anyone...? Anyone...? I wanted to get this done today.
Old 06-26-2014, 10:51 AM   #7
67chevemall
67chevemall's Avatar
Ran mine from the bottom feeder on the carb down the engine through the firewall gromet with the oil pressure line/ dist ign wire, ect.. right to the gauge.
Works great.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 06-26-2014, 12:21 PM   #8
HIGHWAY BY THE SEA
I ended up attaching the tubing to a small metal nozzle that is on the very bottom of the carb that was plugged with a rubber cap. I hope this is what you mean! The gauge does work with this, however it goes down on rev and up on idle. Is this working right? This is my first experience with a VAC gauge.
Old 06-26-2014, 03:52 PM   #9
Already Gone
Down on rev and up on idle is right. The more vacuum you have the less gas you use.
