Old 06-24-2014, 08:59 PM   #1
roger55
roger55's Avatar
Question for those that have an AAW Classic Update harness in their TF
I'm wondering how to install the courtesy light switches in the door jambs. Not sure of the best place to do it or the best way to drill the holes. It looks like drilling the holes might be a little tricky.
Advice or advice with photos would be greatly appreciated.
roger55 is offline   Reply With Quote
Old 06-25-2014, 12:44 AM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Question for those that have an AAW Classic Update harness in their TF
Remove the kick panels and drill a hole above the lower hinge and put the switch in sticking out enough to contact the door. Run the wire up and over the top of the kick panel.
dwcsr is offline   Reply With Quote
Old 06-25-2014, 01:01 AM   #3
DransportGarage
DransportGarage's Avatar
I like Ogre's solution:
http://67-72chevytrucks.com/vboard/s...=501998&page=2
Post #30...
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 06-25-2014, 10:05 AM   #4
roger55
roger55's Avatar
Thanks.
Here are the switches:
It looks like I will need a 3/4" hole. But, it still appears I may need to carefully file notches in the hole for the clip to work.
I don't have a bit that big and I don't want to use a hole saw on these. I guess I'll need to shop for a step drill bit.
Old 06-25-2014, 12:16 PM   #5
Daze57
Daze57's Avatar
step drill bit is the way to go . check the drilled hole alot to make sure you dont get it too big .
i am running the same switches and once i got the hole just big enough they snapped right in tight . good luck sir
i am a AAW fan - good clear concise directions - was worth the money .
Daze57 is offline   Reply With Quote
