![]() Join Date: Feb 2012
LS swap who's headers fit best
A friend of mine is doing a ls swap on a 68 2 wheel drive , any pros and cons on headers for this swap ?
Re: LS swap who's headers fit best
I used aftermarket longtube headers made for a trailblazer ss.. fits great just need to trim a lil here n there..
1969 C10 SWB -- LS 5.3 4L60E , CC LT HEADERS, 2.5" X-PIPE ,P&P THROTTLE BODY, CAI, ELECTRIC FANS, 3:73 GEARS, TRAC LOCK, 22" BOYDS , VINTAGE AIR, DAKOTA DIGITAL, 2013 LTZ LEATHER SEATS, PIONEER DD NAVI, 4.5˝ FIBERGLASS COWL HOOD, MCGAUGHYS DISK BRAKE CONVERSION 2.5 DROP SPINDLE 6/8 STATIC DROP . ![]() |
Copied from a similar post
LSx Swap forum General consensus on no fuss manifolds is Trailblazer SS. Headers you can make fit, but top of the heap and made for our application are the ![]() Here Only cons that I can fathom the expense of the big boys or modification of some close enough models. Otherwise these motors love a free flowing exhaust. |
![]() Join Date: Sep 2005
I used stock trailblaxer ss manifolds cleared everything
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
I used 2010 Camaro manifolds. I like that the exit straight down instead of angled backward.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
I tried to use stock '98 F body manifolds that are sometimes recommended... no go for me. I used a set of block huggers. They fit great and I didnt have to deal with an EGR block off. I'd probably go Pacesetter TBSS headers if I replace them
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
Parts and more parts
There was a forum piece on this website, that had a group buy on the Doug Thorley headers. I have a set in my basement, but have not installed any yet.
https://www.dougthorleyheaders.com/p...PICKUP/sfID1/9
Frank |
![]() Join Date: Sep 2011
How about a little more info on what motor mounts/stands/frame position were used.
I see a lot of header threads but limited info on the setup which could make or break a certain combo......
1967 C10 SWB Owner - Rustbelt Restorations |
I used Pacesetter Coated Long tube LS1 header and I am pleased.
http://www.texas-speed.com/p-280-pac...1-headers.aspx |
The engine was installed with the tubular CCP motor mounts, but the POL mounts would also work. The Doug Thorley headers were designed for just this truck frame and the LS engine combination
Frank |
I ended up with the ece/dirty dingo mounts and headmen husler mid length headers.
1 3/4. with 3' collectors, no frame mods needed. |
![]() Join Date: May 2013
http://67-72chevytrucks.com/vboard/s...d.php?t=585605
Might interest you , if you have questions please ask , I as most on here live for this stuff , ccp has changed their mounts , they are no longer tubular but made of plate , and actually work , as opposed to my situation with their old style mounts , nite mare
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
