The Diffference between the 67-72 Chevy Trucks (Year Breakdown Version)
I put this together from this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=323797 from which most things were cut and pasted.
I am attempting to make a table that will give a somewhat easy reference for the differences between the truck years. In doing this I have learned that there is almost as much uncertainty as there is fact. I would like this to become an ongoing database that people add to. If someone offers something new in a reply and someone can confirm it, I'll go back and edit the table. If someone has a suggestion to make it easier to read or organize, please let me know. Thanks to GOPAPA who put the first thread together and to those that contributed to that one. --------------------------------------- For those of you who are learning about these trucks, it's fairly easy to tell what year they are. The six years of production, from 1967 to 1972, are divided up into three groups of two years. We have the '67-'68 trucks, the '69-'70s and the '71-72s. 1967 - 1968 Easy initial Differentiation: Slanting hood front with "C-H-E-V-R-O-L-E-T" spelled out across front in chrome letters. Large rectangular grille openings with Bowtie in center of grille. '67 - '68 Unique: Pull handle parking brake, throttle was controlled through mechanical linkage, bench seats offered full-depth foam and a tip-forward design and the 1968 Custom package could include a cloth interior and padded door panels, bearing type ashtray, door hinge differences from later years '67 : Bowtie fender emblems, Small back window ("Panoramic window option [Big Window]), No side marker reflectors/lights, unique vent wing knobs, unique exterior door handles (mounting screw angles), Outward dimpled rail for ashtray that is straight, power steering was a ram-style system, unique ignition bezel style, unique armrests (different mounting screw angle), may not have dimple in frame to accomodate power steering box, K series trucks used the closed knuckle Dana 44 with drum brakes, some base models only had driver's side visor, interior knobs screw on Engine options: 250ci and 292ci I6, 283ci and small journal 327 V8, 351ci V6 only in GMC Transmission options: 3 speed manual, 3 speed manual with OD on 1/2 ton only, 4 speed manual, powerglide and Turbo Hydra-matic automatics Trim Levels: C/10, Custom/10, CST/10; GMC 1500 Custom 1500 Super Custom 1500 '68 : 50th Anniversary Truck option (this one has been lowered, interior), Side marker reflectors, Introduced Longhorn, early production could have '67 style ignition bezel, may not have dimple in frame to accomodate power steering box, K series trucks used the closed knuckle Dana 44 with drum brakes, indented arched bearing ashtray guide Engine options: 250ci and 292ci I6, 307ci , large journal 327ci, and 396 V8, 351ci V6 only in GMC Transmission options: 3 speed manual, 3 speed manual with OD on 1/2 ton only, 4 speed manual, powerglide and Turbo Hydra-matic automatics Trim Levels: C/10, Custom/10, CST/10; GMC 1500 Custom 1500 Super Custom 1500 1969 - 1970 Easy Initial Differentiation: Upright hood front with Chevrolet Bowtie in center, Aluminum grille bar with "CHEVROLET" spelled out. Parking lights in grille bar. Model/series fender emblems. '69 - '70 Unique: '69 : Introduced Blazer, foot operated parking brake, crate style grill insert, K series trucks used the closed knuckle Dana 44 with drum brakes, indented arched bearing ashtray guide Engine options: 250ci and 292ci I6, 307ci, 350ci, and 396 V8; 351ci V6 only in GMC (dropped midyear) Transmission options: 3 speed manual, 3 speed manual with OD on 1/2 ton only, 4 speed manual, powerglide and Turbo Hydra-matic automatics Trim Levels: C/10, Custom/10, CST/10; GMC 1500 Custom 1500 Super Custom 1500 '70 : Introduced Jimmy, foot operated parking brake, luvered grille insert, K series trucks switched to the open knuckle Dana 44 with drum brakes, indented arched bearing ashtray guide Engine options: 250ci and 292ci I6, 307ci , 350ci, and 402ci V8(called 400) Transmission options: 3 speed manual, 4 speed manual, powerglide and Turbo Hydra-matic automatics Trim Levels: C/10, Custom/10, CST/10; GMC had custom, super custom, sierra and sierra grande 1971 - 1972 Easy Initial Differentiation: Upright hood front with no Chevrolet Bowtie, Egg crate grille with Bowtie in center. Parking lights in bumper. Model/series fender emblems. '71 - '72 Unique: Indented arched bearing ashtray guide, chrome sport mirrors, Throttle cable (instead of throttle rod) '71 : Introduced front disc brakes, raised pad for rearview mirror, foot operated parking brake, K series trucks had the open knuckle Dana 44 with disk brakes, outward bearing arched ashtray guide Engine options: 250ci and 292ci I6, 307ci , 350ci, and 402ci V8(called 400) Transmission options: 3 speed manual, 4 speed manual, powerglide and Turbo Hydra-matic automatics Trim Levels: Custom, Custom Deluxe, Cheyenne, Cheyenne Super; LATE '71 Cheyenne, Cheyenne Super, Cheyenne Highlander; GMC Custom 1500 Super Custom 1500 Sierra 1500 LATE '71 Super Custom 1500 Sierra 1500 Sierra Grande 1500 Sierra Highlander '72 : Rearview mirrow mounted to windshield, plastic door panels, foot operated parking brake, K series trucks had the open knuckle Dana 44 with disk brakes, outward bearing arched ashtray guide, unique window crank/regulator Engine options: 250ci and 292ci (20's and 30's only) I6, 307ci , 350ci, and 402ci V8(called 400) Transmission options: 3 speed manual, 4 speed manual, Turbo Hydra-matic automatics Trim Levels: Custom, Custom Deluxe, Cheyenne, Cheyenne Super, Cheyenne Highlander; GMC Super Custom 1500 Sierra 1500 Sierra Grande 1500 Sierra Highlander Links to some other references: Chevy Differences: http://www.pattson.com/maych/67_72_chevy.htm GMC Differences: http://www.pattson.com/maych/67_72_gmc.htm RPO codes: http://outintheshop.com/options.html '67 Model Number Info / VIN Decoder '68 Model Number Info / VIN Decoder '69 Model Number Info / VIN Decoder '70 Model Number Info / VIN Decoder '71 Model Number Info / VIN Decoder '72 Model Number Info / VIN Decoder Thanks to any and all who contribute, even if just to ask a question. Most of the hyperlinks to pics will be from this website, that I have saved to my Imgur account. Thanks to those whose pictures I have used, even if you don't know it. Disclaimer: This is not intended to be perfect. I don't believe it will ever be 100% accurate as a lot of the information to confirm things is lost.
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. Last edited by LSUMurse; 07-16-2014 at 09:24 PM. |
Re: The Diffference between the 67-72 Chevy Trucks (Table Version)
That got a lot larger than I thought it would be. Maybe it's not easier to read. Let me know if this is just a wasted effort.
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
Power windows in '72. I've never seen one.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
Someone questioned that in the other thread. Removed.
![]() Join Date: Nov 2001
I believe that my 67 CST 1/2 ton came factory with a 327cid and a TH400 transmission.
I don't see that as an option for 67. Great job on the list. I never really knew how to tell the 69's from the 70's before. Thank you for posting this table.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
i don't know why i was thinking you would show the differences in sheetmetal pics (kinda like an LMC). Then again i guess i could look at an LMC.
![]() still a good thread ![]() |
Is there a 350ci V6?
"I taste Rust" I wish I had the money my truck thinks I do I taste "Patina" |
good info. just breaking your balls here but that isnt a table.
needs Pics to really make it useful. A lot of that stuff only helps if you know what you are talking about. ie what is a 67 style ignition bezel? |
#9 | |
67 bezel now has a hyperlink to a pic. Title changed.
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. Last edited by LSUMurse; 06-25-2014 at 05:46 PM. |
Lots of great info and work there LSU I thought about those power windows a couple of times this morning though. Still lots of good work you put in and I do thank you and enjoyed it very much. Jim
Thanks. It did end up being a little more than I thought it was going to be. You've been here a while. Please make suggestions or additions if you have any. My biggest concern is disinformation. I'm going to do my best but the community can be a big help.
In looking around the net, GMC made a 305 and a 351 V6. Now I have to figure out if it was a 305 typo, or truely a 351.
#13 |
![]() Join Date: Feb 2003
very nice work and thx for the effort. heres a correction... in 1971 2 wheel drive could be ordered with turbo 400
Body options: Engine options: 250ci and 292ci I6, 307ci , 350ci, and 402ci V8(called 400) Transmission options: 3 speed manual, 3 speed manual with OD on 1/2 ton only, 4 speed manual, powerglide and TH350 automatics, 4wd could order TH350,TH400
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
#14 |
![]() Join Date: Feb 2002
Cool table. Just a few notes. I have a '67 K/10 Suburban, it has a slide ashtray [which is not compatable with the slide ashtray in my '71 GMC Jimmy K/1500 4x4 ''Custom''.] My '68 C/10 Stepside has the ball-bearing ashtray -- called the "Deluxe Ashtray" on the build sheet, which has since disintegrated and lost itself, but not mentioned on the SPID.
Also GM for whatever reason refered to inline engines as "L6s'' back in the day, not 'I6s' which Ford uses. Now GM calls them I6s too, but if you want pure historical accuracy, say "Ell Six." The Iron Duke 152 CuIn was an L4, but not a truck option in the '67 - '72 period.
#15 |
Vintage 4x4s
Yep 305 and 351 V6's. I think 69 or 70 was the last year you could get either in a pickup though.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#16 |
WOW! Cool!!! (I didn't mean to distract from the tome of the thread).
#17 |
I plan on making some hyperlinks to show differences
#18 |
It's got a smaller diameter on the surround and no ACC function.
#19 |
I like the idea but the multiple colors are (to me) a negative to taking it seriously.
Deciding how to present the info is difficult. I would look at a relaxed standard US book style format and use that until a better idea came along. I'd also use USA capitalization rules. Capitalize the first letter of a sentence, proper nouns, and not much else. Basically, when in doubt, don't. Same with commas. |
#20 | |
#21 | |
As far as the capitals and such, I do a lot of start and stop typing and adding things to one spot and going to another, so that'll explain a lot of the punctuation errors. I do plan on proof reading it in 16 years when I finally finish it. ![]()
#22 |
1969 GM Heritage website information kit only lists 250/292 six cylinders and 307/350/396 V8's. There is no mention of a 327. Can anyone verify yes or no?
#23 |
Th400 and power glide only auto offered in 67 and 68, the special air vent handles( lower) only on 67-68, 67 used different control knobs on dash than 68-72, no 327 in 69. 283 & 327 only v 8 offered in 67. 283 replaced by 307 in 68, 396 offered first year in trucks in 68. 396, 307, 350 offered in 69. In 70 396 badged as 400 but could still be list on spid as 396. 71 /72 badged as 400 CID but actually 402 cid. No th400 offered ever in 4x4 in these year model trucks only th350. Th350 and th400 use same spid call out, and only diff. On spid being a star for 2wd drive trucks. No custom deluxe, Cheyenne or super offered in 70. C10, custom or cst only. Cst replaced in 71 with Cheyenne, same trim level, c10 replaced with custom as low level, custom deluxe mid level , Cheyenne high option. April of 71 super officially introduced, and becomes top of line.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle Last edited by 71 super; 06-26-2014 at 05:54 AM. |
#24 | |
By "special air vent handles" are you referring to the ones down in the kick panels?
#25 |
