Old 08-04-2003, 01:42 PM   #1
charles oliver
68 camtruck
charles oliver's Avatar
Question Dash Panel Replacement
Has anyone tried using the 69 up dash panel with gauges on the older 67, 68 truck. I tried and the wireing must be different. Do you have to change the Wireing Harness also ?
Any Ideas ?
Charlie
charles oliver is offline   Reply With Quote
Old 08-04-2003, 01:58 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
You'll have to clarify some. If you are replacing an idiot light dash with guages, then the wriing is different. These dashes require different harnesses to work properly. You can re-wire the existing one, I think there is a guide at www.gmcpauls.com.
If you were swapping apples for apples, the only difference is the light and wiper switches are both on the LH side. Consequently, the length of the wiring for wiper switch is not the same.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 08-04-2003, 02:05 PM   #3
charles oliver
68 camtruck
Yes, I am swapping the idiot lights for gauges. Any idea if I just need the inner harness or do I need to switch the whole thing ?
Charlie
Old 08-04-2003, 02:20 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
click here for GMCPauls FAQ on this
Old 08-04-2003, 03:36 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you already did this, your fuel guage is probably toast.
It was pretty fun watching it spin though wasn't it?
Old 08-04-2003, 05:59 PM   #6
charles oliver
68 camtruck
Lognhorn, are you saying if I already tried to plug in the Gauge Cluster to the existing Idiot Cluster, I fried my fuel Gauge ?
Charlie
Old 08-05-2003, 12:01 AM   #7
jewels.
jewels.'s Avatar
ttt
longhorn, i'm curious to hear the answer to this one....
jewels.
68 C10 Red Step 350 my first child & main focus
58 3200 Apache LWB Step the upcoming project
jewels. is offline   Reply With Quote
Old 08-05-2003, 04:23 PM   #8
Longhorn Man
Well, I know mine fried as soon as I turned on the ignition switch, and a dude I know refused to listen to me and did the exact same thing, with the same results.I might have been cranking it over when it actually fried, but either way.
