Old 06-25-2014, 06:33 PM   #1
davepl
davepl's Avatar
Sensor (oil, temp) issues
I'm having two issues. 1970 402.
a) I cannot for the life of me figure out where the temp gauge sender goes. I know it had one because the gauge didn't work, and I checked its resistance. I just don't remember where it was, have no photo of it, and the assembly manual shows it at the water neck. That I -do- have photos of and it wasn't there.
b) On the oil side, I have the oil pressure tube connected to the center hole of the three that are available above the oil filter on the big block. I cannot, however, seem to thread the idiot light sensor (blue wire) into the little hole. It looks like the same size, but maybe there's paint in it, or it's not a tapered thread, or some difference, or LMC sent me a metric thread sensor. I'm out of ideas.
Similarly, I'm going to have to plug whichever plug hole I don't use, and I don't know what'll fit.
And tips welcome!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-25-2014, 06:35 PM   #2
davepl
davepl's Avatar
Re: Sensor (oil, temp) issues
Found the temp sensor; machine shop put a square plug in it; usually they'd use a hex pipe plug so I thought the plug was OEM (always there). Then I finally found a photo I had.
If it helps, the oil pressure sender I have appears to be 3/8-24 tapered pipe thread. Still stuck on those two. On my 427/390 it's T'd off to gauges and light, but those cars (from the factory) have one or the other, not both (light and gauge).
Old 06-25-2014, 06:53 PM   #3
davepl
davepl's Avatar
Now I'm confused. The truck dash has BRAKE and TEMP lights. No oil light. Maybe the M&H harness doesn't distinguish between gauge and idiot light trucks?
