Old 06-25-2014, 08:25 PM   #1
1963chevyc20
1963chevyc20's Avatar
Fixing to purchase an 86 c20
My grand dad purchased a 86 c20 with a utility bed at a school auction in Dallas. It look really good. What should I look at tho. Where are the common rust spots, what mileage will it get with a 350 4 speed Manuel. He said he did not know if the utility bed was origional but thinks it is. Was it an option? I love the looks of a 74 grill. Will it fit on an 86? New to the 80 model trucks. It Jill be a WORK truck. Wil I'd do good? will put picks up of I get it next weekend.
1963chevyc20 is offline   Reply With Quote
Old 06-25-2014, 08:26 PM   #2
1963chevyc20
Re: Fixing to purchase an 86 c20
Oh forgot to say he is to old to drive. He got it 2 years ago. He is selling it to me for 500 cash
Old 06-25-2014, 08:35 PM   #3
86c20
86c20's Avatar
look at my list that will tell you what you will get. rust is cab corners rockers and back window.
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 06-25-2014, 08:39 PM   #4
1963chevyc20
I will be sure to check
Old 06-25-2014, 08:49 PM   #5
86c20
86c20's Avatar
mpg is all about gears and rpm. and for the love of god man post so pics i love c20's
Old 06-25-2014, 08:59 PM   #6
1963chevyc20
I will get picks When I head to Dallas to get it. I live 2 hrs away from it. I do have a 63 c20 with picks on it and a vid.
Old 06-25-2014, 09:46 PM   #7
tucsonjwt
I have had 3 C20 square bodies. For $500, you likely have enough in parts to cover the vehicle cost if it turns out to be a lemon.
You probably already know this, but if you want this to be a reliable driver, you can expect to replace all of the wear parts on the truck, unless they have recently been replaced (tires, brakes, front suspension, shocks, alternator, starter, etc., and don't forget the air conditioning parts, if it has a/c).
Bring a small tarp to crawl under the truck with a flashlight to check it out. If it looks rusty I would walk away. Check around the cab rear corners and in the outer corners of the cab floor. Check the gas tank brackets to see how rusty they are on top of the brackets (hidden) where the brackets support the tank. While you are on the ground, check the bottom of the doors and the rocker panels for rust.
Good luck.
tucsonjwt is offline   Reply With Quote
Old 06-26-2014, 08:43 AM   #8
Keith Seymore
Keith Seymore's Avatar
Utility box would not be factory; only fleetside, stepside, or no box as factory options.
'74 grille will not fit '81 and up, unless you want to change the whole front end over (fenders, hood, rad support, etc).
Check out my build thread, linked below (Intro from an old Assembly guy) to see the restoration on my truck, for typical rust spot and repair.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
