06-25-2014, 08:43 PM | #1 |
Electirc Choke help
I have question.. After repairing and cleaning up my wiring. I found a wire that wasnt hooked to anything. traced the wire.. well it for my electric choke on my carb. I assume this wire is to have 12v at ign on/run ?? would if matter where I get my 12v from.. I was just going to run a new wire to fuse panel. Hopefully this is the issues of my truck bogging down on accel. Thanks in advance !!
64 C10 Stepside 350/4psd Driver/Project on air. Dom bags, Dual Viair and AccuAir 08 Ford F150 Limited- F-word ! Daily Driver .......................____ ..........._______l/ \____ ...........|_/(0)\_ll____/(0)_l. |
06-25-2014, 10:25 PM | #2 |
Re: Electirc Choke help
Yes. The choke wire needs to come on with the switch. You can hook in in the fuse panel but it needs to be fused.
06-29-2014, 06:08 PM | #3 |
This thread was added to the The Engine Bay category of your 60-66 FAQ Index.
-W NOTE : if this link changes in the future, look for the sticky at the top of the 1960-66 Message Board. |
06-29-2014, 09:51 PM | #4 |
06-29-2014, 09:57 PM | #5 |
You could tap power from the choke but the heating element draws a lot and will drop the voltage to the coil wire unless it is sized up accordingly.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
