Old 06-25-2014, 09:45 PM   #1
AsianBlazer
Active Member
AsianBlazer's Avatar
Brake upgrade options
Hi guys,
I have a 71 K5 with the stock single piston caliper disc brakes. Is there a late model Chevy brake system which will bolt up, possibly a 4 piston caliper, or is the best option an aftermarket Wilwood or Baier system? I am just finishing up a rotisserie resto/mod on it, just need to paint the new hood (Thanks Wes at Classic Heartbeat) and then work on the details i.e., wheels, tires, etc.
Thanks for looking,
Mike
AsianBlazer is offline   Reply With Quote
Old 06-26-2014, 02:07 AM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Brake upgrade options
Not sure if the Wilwood D52 calipers work on the 4wd. I know they work on the 2wd trucks. Otherwise, I dont think anyone makes a kit for the D44 front. You can add rear disc brakes too but the emergency brake may be an issue. I dont like the El Dorado caliper that most kits use.
Rich
1972 K5 Blazer CST Click HERE
Old 06-26-2014, 09:34 AM   #3
DemkoG
For upgraded brakes the D52 do help, I put them on a grand wagoneer and you can tell a difference, but what I feel helps more is a dual diaphragm brake booster (25% more force) and better master cylinder. Hydrobost is a option but I have not been a fan of the one in my f350 but a lot of people love them. On my blazer I will be using a dual diaphragm brake booster, rear disks (no e-brake) and the d52 up front.
DemkoG is offline   Reply With Quote
Old 06-26-2014, 10:22 AM   #4
DemkoG
Sorry re did the math the dual diaphragm is just a bit more braking pressure.
