Old 06-26-2014, 12:21 AM   #1
SierraMtns
SierraMtns's Avatar
Possible To Convert Back?? (Roll-Up Windows)
Good Evening Guys,
I want to convert the windows back to roll-up. The previous owner had a shop convert the windows to electric. I am not sure about the details of the kit that was used. The only info I know is which local glass shop cut the glass.
So before I jump into ripping all the wiring out. I wanted to ask the great minds on here a couple questions.
1. Is it possible to keep the 1 piece window and have it be roll up?
2. Will the stock OEM roll-up mechanism work?
Pictures.
SierraMtns is offline   Reply With Quote
Old 06-26-2014, 12:41 AM   #2
wreckedchevy
wreckedchevy's Avatar
Re: Possible To Convert Back?? (Roll-Up Windows)
can't help you with the ? but had to say that looks like a really nice stepper you got
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline   Reply With Quote
Old 06-26-2014, 02:47 AM   #3
Beaumont@
Anything is possible. To use a stock window crack would require some modification for sure.
Beaumont@ is offline   Reply With Quote
Old 06-26-2014, 12:20 PM   #4
SierraMtns
SierraMtns's Avatar
I also thought about getting stock window and vent and seeing if I can cut them down to work with the 3" chop.
Anyone know of any C10 chopped with stock windows? I found 1 picture online of a 68 chopped 3" with stock windows.
Old 06-26-2014, 12:33 PM   #5
mr48chev
mr48chev's Avatar
The only possible problem I see is that the window might hang up a bit up in front because you will have about four inches more glass at the front than you had before.
What did they use to convert the windows to power? it looks like they may have used factory replacement regulators and in that case all you need to do is get a good pair of manual regulators and install them and done.
If the windows went up and down perfectly I'd be inclined to leave them alone and be done with it though. It's kind of nice to be able to hit the button and roll the passenger window up or down without stopping the truck and sliding across the seat to do it.
My ongoing truck projects:
Old 06-26-2014, 05:22 PM   #6
casper71
I would try installing the crank window assembly before removing everything. That looks like they used a factory style power window kit.
casper71 is offline   Reply With Quote
Old 06-26-2014, 10:19 PM   #7
69chevy lwb
69chevy lwb's Avatar
I made some one piece Windows for a friend that use manual cranks but it was all built together. His truck is chopped about 8 inches. I cut them out of laminated but you could have tempered glass made if you wanted. I also cut the windshield for this truck
69chevy lwb is offline   Reply With Quote
Old 06-27-2014, 07:11 PM   #8
SierraMtns
SierraMtns's Avatar
I went back though my papers on the truck and found the local shop that did the windows. All the paper work says is "1 piece window kit" ($690). The grand total for 4 windows cut and electric windows installed was $3066.62. WOW.
My plan is to run by the shop next week and see if they can help me with putting hand cranks back on.
Old 06-28-2014, 12:40 AM   #9
fastlane
fastlane's Avatar
They make a "button" you can use to get the original cranks to work the power windows. I think the push buttons like the ones you have look ridiculous and are awkward to use. Autoloc is one manufature I'm going to buy mine here... Just incase it is just for the looks, I wouldn't go back to cranks after having power.. but thats just me. Good luck
1969 Chevy C/10 Stepside, Short Box. LQ4/4L80E swap in progress! (Donations being accepted!)
fastlane is offline   Reply With Quote
Old 06-28-2014, 08:07 AM   #10
69 MOD
69 MOD's Avatar
Here is just the switches:
http://www.ebay.com/itm/HOT-STREET-R...3D300943725045
I'm sure they are cheaper somewhere else, just wanted to let you see the style...
Chad
'71 GMC 2500 Custom Ol Blue
'72 Custom Deluxe Highlander Stuffed Olive
'73 Trans Am
'13 Silverado 2500 Duramax Storm Trooper
69 MOD is offline   Reply With Quote
