Old 06-26-2014, 01:48 AM   #1
ho70
ho70's Avatar
Wiring question
Been through the threads and.....
1) HEI wire to the ignition unfused on the fuseblock.
2) Have electric choke and I should add a 10 amp inline fuse and connect to other ignition unfused terminal in fuseblock
3) when I add tach, should I tap into ignition unfused as well, say piggyback with choke wire?
ho70 is offline   Reply With Quote
Old 06-28-2014, 11:17 AM   #2
ho70
ho70's Avatar
Re: Wiring question
anyone?
Old 06-28-2014, 11:35 AM   #3
leftybass209
leftybass209's Avatar
Re: Wiring question
That's one way to do it I suppose. I purchased some packard 56 terminals from Napa and ran one of my wires through the original harness. If you look in your firewall wire gutter there should be a terminated wire sitting up there unused. That's the wire I used for choke.
leftybass209 is offline   Reply With Quote
Old 06-28-2014, 01:03 PM   #4
ho70
ho70's Avatar
Re: Wiring question
Old 06-28-2014, 03:55 PM   #5
trac209
Re: Wiring question
If You mean just it's power wire then yes you can go to any keyed power source. I'm sure your aware the other goes to the distributor.
trac209 is offline   Reply With Quote
