06-26-2014, 01:00 PM | #1 |
Replacing brake lines
The brake lines on my truck are fairly rusty and I want to replace them. LMC has pre-bent lines for sale, but I want to make my own.
I have a 1971 C20 with power disc brakes in the front. Before I start ripping out the old lines I want to have everything ready. I've never done this before, so I need some pointers. Are the steel lines for my truck 1/4"? Can I just get a roll of these: http://shop.advanceautoparts.com/p/p...08%7CL3*15690# and then double flare them/bend/cut them? I'm mostly concerned about the connections- where do I get the brass fittings that screw into the MC and such, and how do I know which ones to get? I can't seem to find them on auto parts websites. I'd appreciate any help, thanks. |
06-26-2014, 01:50 PM | #2 |
Re: Replacing brake lines
I bring my brake parts with me. I brought my MC and proportioning valve with me to one of the chain stores to pick the correct fittings, between the two parts, I needed 3 different fittings! The chain stores will have all of the fittings, but they may be "behind the counter."
I've never used the rolled line before... I always buy the straight pieces. Every other flaring tool I used that was "cheap" was crap and didn't make the flares right. Eastwood makes some killer tools for bending/flaring, but be prepared to open your wallet. Flaring tool: http://www.ebay.com/itm/Eastwood-Pro..._Tools&vxp=mtr Bending tools: http://www.ebay.com/itm/Eastwood-Bra..._Tools&vxp=mtr In this case, since you're "going back to factory", and/or don't plan on really flaring and bending lines again any time soon, you'll be much better off buying pre bent lines. I'm a tool junkie and I had to "make up" the lines for my mustang and I have a couple other projects I'll be using the tools for.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
06-26-2014, 02:19 PM | #3 |
Old Skool Club
Check out www.inlinetube.com
They have pre-bent lines in stainless for a little bit more than mild steel. But, they also have the tools that are for making your own, too. But, you gotta invest in them, first. Which is why I am going to order mine from them, instead of buying tools I will never need again. But, my chassis is naked and now's the time to put them on.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
06-26-2014, 04:34 PM | #4 |
The Older Generation
I used the newer NICOPP brake lines (nickel+Copper+Iron) on one of my projects. Really easy to bend and they will not rust. CNC 325 is 3/16" and CNC 425 is 1/4". I bought mine from this guy: http://www.ebay.com/itm/CNC-325-3-16...d=141112260250 http://www.ebay.com/itm/CNC425-1-4-C...d=141112260250 Best price I could find at the time. You can actually coil it around a 1" wooden dowel by hand without kinking it. It also flares easy with a regular double flaring tool and there are coated flare nuts available. Some of the auto parts stores carry it but it is quite a bit more $. LockDoc
06-26-2014, 05:23 PM | #5 |
I used this tool to bend 3/16" stainless lines. it was pretty easy to bend. You can see the tight bends I made to accommodate the Wilwood Master and Proportioning valve. The hard part was flaring the stainless.
Amazon.com: Lisle 44150 3/16" Tubing Bender... |
06-26-2014, 05:40 PM | #6 |
i bought mine from www.inlinetube.com
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
