Old 06-26-2014, 02:05 PM   #1
tpimuncie
tpimuncie's Avatar
1955-59 inner door bottom replacement
Anyone have any pointers when doing these patches? thanks in advance
1959 apache 1948 chevy coupe
http://67-72chevytrucks.com/vboard/s...d.php?t=562949
1964 gmc burban build for pops
http://67-72chevytrucks.com/vboard/s...d.php?t=724632
tpimuncie is offline   Reply With Quote
Old 06-26-2014, 05:54 PM   #2
_Ogre
_Ogre's Avatar
Re: 1955-59 inner door bottom replacement
make a cardboard template of the door profile front and back
check the profile before you weld it
shop air compressor timer
Old 06-26-2014, 10:50 PM   #3
roger55
roger55's Avatar
Start with this post and then look at posts #253,309,313,315,517,521,526 and 532
http://www.trifive.com/forums/showth...04#post1208904
roger55 is offline   Reply With Quote
Old 07-01-2014, 02:35 PM   #4
unstable
Years ago I seen an article posted on Brothers where they clamped the patch over the top of the old area, cut through both layers, removed the old metal and then welded in the new. That's the approach I've been using and it works pretty good for the most part. Just as long as you have a tight fit of the panels to begin with, you'll be good.
What I like about this approach is, if you end up not cutting perfectly straight or whatever, the panel will still line up.
unstable is offline   Reply With Quote
Old 07-01-2014, 10:41 PM   #5
butchp
I completed the pass side and am doing the driver side now. Watch out for the outside pannel it is formed on the outside edges but not in the center I had to make a buck to form it in the center section if you look you can see it is not formed if you weld it without forming it will pull the outside down by a 1/2". Ask me how I know.
butchp is offline   Reply With Quote
