Old 06-26-2014, 02:17 PM   #1
nheller76
nheller76's Avatar
Steering gear box rebuild
Hey guys, so my steering box is leaking! Has anyone tried to rebuild one? Do you have any idea how to? I need some help. Thank you.
Faith and Patience with my truck, that is what i pray for every day!
See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013
nheller76 is offline   Reply With Quote
Old 06-26-2014, 02:20 PM   #2
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Steering gear box rebuild
Its just as easy as following this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=619634
If you have an Auto Zone close, you should be able to get the Pitman Arm puller tool from their loan a tool program.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-26-2014, 05:55 PM   #3
tucsonjwt
I would just get a rebuilt one. I got one from Auto Zone maybe 10 years ago and it is holding up well. I have seen the core value from $30 to $150, so it will pay to shop around. Mine only cost about $25 because the core value at that time was about $90.
I would check youtube for videos on replacing the steering gear - even later models will give you a good idea.
You can also check the usual online suspects:
www.rockauto.com
www.oewarehouse.com
www.oehq.com
www.gmapartsdirect.com
www.autopartstomorrow.com
tucsonjwt is offline   Reply With Quote
Old 06-26-2014, 08:33 PM   #4
y5mgisi
Second Chance Program
y5mgisi's Avatar
In my opinion, they are a pain in the ass! I wont rebuild one again. As far as just re-sealing one, they arent too bad. Its when rebuilding one and dealing the the Teflon seals and ball bearings that it starts to suck.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 06-26-2014, 09:32 PM   #5
Ziegelsteinfaust
I just paid $150 to get my pump, and box rebuilt plus the steering weight tightened up. The kits alone for a quality set were $85.
Ziegelsteinfaust is offline   Reply With Quote
Old 06-27-2014, 01:01 AM   #6
tucsonjwt
Plus, if it does leak after you are done with your rebuild you won't have a warranty like you should have from the parts store or service shop. I like the idea of pump. box, lines, all replaced at the same time, maybe even a new rag joint.
