Old 06-26-2014, 03:21 PM   #1
Bhaynes702
Bhaynes702's Avatar
HELP! Th350 to Which over drive tranny?
Help! I need overdrive! What is the best tranny to go with? This is my daily driver and the gas is killing me. What I have is
66 GMC step side short box
305 CID out of a 85 GM
600 CFM Holly carb
TH350 tranny
As far as the rear end no sure yet
I'm looking at putting a 700r4 in it and need to know the best way and cheapest way about it. I'm a little over budget at this point ( I married a accountant). There is no computer all old school stuff. Except for the candy apple paint your help would greatly be appreciated
Bhaynes702 is offline   Reply With Quote
Old 06-26-2014, 04:15 PM   #2
Captainfab
60-66 Nut
Re: HELP! Th350 to Which over drive tranny?
There are many, many, many threads in the Engine and Drivetrain' section of this forum on how to properly setup the TV cable and the TCC lockup on the 700R4. The TV cable is probably the absolute most important part of a 700R4 installation. If not done correctly, you will burn up your trans in a short time.
As for the rest of the installation, it really is quite simple. Especilly since you already have an auto trans now.
Old 06-27-2014, 01:30 AM   #3
pestwagon
I replaced my TH350 with a 200R4 by Bowtie Overdrives (guy in Los Angeles sold my his with low miles and torque convertor for 1100. Mileage went immediately from 9-10 to 15-16. With lock up engaged truck cruises 65-70 all day...
pestwagon is offline   Reply With Quote
Old 06-27-2014, 02:08 AM   #4
padresag
I take that it is a 305 sbc and not a 305 gmc(even though they were not in production in 86).
what mpg are you getting now and what is your rear axle ratio? you probably don't require a 600 carb
how deep is your foot in it?
ron
padresag is offline   Reply With Quote
Old 06-27-2014, 06:57 AM   #5
PGSigns
PGSigns's Avatar
If you g with a 700 you will need to shorten the drive shaft. Also get the TV made easy kit from Bowtie overdrives. Shifter of your choice. One thing that may also help out is swapping the rear gear to a 308. Most these trucks have a 373 in them.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-27-2014, 07:41 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Jimmy
Shortening the driveshaft depends on which TH350 he currently has. If they used the Th350 out of the same donor truck as his 305 engine, he will be good to go as is. There are three lengths of Th350 trans, the 6 inch, 9 inch, and 12 inch. The 700r4 is the same length as the 9 inch Th350 and consequently no driveshaft mods needed at all. In the 80s trucks, the Th350s used were 9"ers. Only way to know is gonna be to climb under there and measure the tail housing.
Old 06-27-2014, 09:40 AM   #7
parrisc19844x4_468
parrisc19844x4_468's Avatar
You may want to consider converting your th350 to a lock up, that may be an option. When I just had my rebuilt they offered me that for extra $50.
The tranny builder claimed these would give me 2-3 mpg more. I don't drive it much so was not a consideration for me.
Not sure what else would have to be done though, experts may know
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
Old 06-27-2014, 10:13 AM   #8
Dubnova
I think a 200r4 is the same size as a 350 so it should bolt up.
Dubnova is offline   Reply With Quote
Old 06-27-2014, 10:39 AM   #9
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I personally like the 200 better then the 700 due to a better 1-2 gear spacing. I hate the big drop between 1st and 2nd on the 700. The 200 is like a t350 with an overdrive gear. Both need to be built up to handle any power as they both kind of sucked from the factory.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-27-2014, 10:42 AM   #10
NEWFISHER
NEWFISHER's Avatar
"" 600 CFM Holly carb ""---to big for your set up
"" As far as the rear end no sure yet ""---if it's 3:07 or 3:42 you will be unhappy with a 2004r or 700r4 conversion
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 06-27-2014, 05:07 PM   #11
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I agree with the carb comment above.. The PO of my truck had a 750 on my 305. I replaced that with a 500cfm Edelbrock and it has worked a lot better.
I don't know much about the 200R4, but I if your are looking at the 700's, the earlier years of them have less or no electronics on them. Maybe around the early 90's.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-28-2014, 10:37 PM   #12
NEWFISHER
NEWFISHER's Avatar
If you go 700r4 you want an MD8 case. This was the later style and had all of the internal upgrades. Bowtie overdrives is a great trans supply company with good answers to any questions.
GOD BLESS AMERICA!
Old 07-04-2014, 09:25 AM   #13
Bhaynes702
Bhaynes702's Avatar
The condition I purchased the truck in was raw ill try to load the picks the rearend I'm unsure on but the engine block numbers are for a 85 GM. I,m trying to make it a daily driver. I'm not putting my foot in it at all. I'll double check the length of the tranny in it.
Thanks for all your help
Old 07-04-2014, 09:49 AM   #14
Bhaynes702
Bhaynes702's Avatar
Pic when I got the truck no interior no wiring or steering gutted inside
Old 07-04-2014, 09:51 AM   #15
Bhaynes702
Bhaynes702's Avatar
This is now
Old 07-04-2014, 10:37 AM   #16
Jeff La
Originally Posted by Bhaynes702 View Post
This is now
Man really nice stance, what size tires are you running???
Jeff La is offline   Reply With Quote
Old 07-04-2014, 12:41 PM   #17
Bhaynes702
Bhaynes702's Avatar
Running P275/60R15 all away around.
Old 07-04-2014, 06:05 PM   #18
chevyrestoguy
chevyrestoguy's Avatar
Measure the tailshaft length per Tx Firefighter's suggestion, and then you'll know what direction you need to go in. Not having to shorten your driveshaft will save you a couple of hundred dollars.
Keep the Holley 600 carb, it's not too big, you'll be just fine. People tend to forget that the factory Q-Jet that they put on the 305 SB back in '85 was 650 cfm. If you're looking for maximum fuel mileage with a carb, a Q-jet is a good choice. Just remember that when you crack the secondaries, that all goes out the window. Bowtie Overdrives makes a kit called "TV Made Easy", and it has all of the adapters you need to hook the TV cable to your Holley linkage. As mentioned earlier, the adjustment of the TV cable is critical. It's not hard to adjust, but just make sure you do it before you decide to take the truck for a test run after the transmission install. You can smoke a 700r4 quickly if you don't.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
