Old 06-26-2014, 06:08 PM   #1
ncmike
02 Silverado V8 5.3 losing antifreeze
Leaks about a pint or so every 200 miles with no noticable sign where leaking at. Should I try some stop leak or do I have a bigger problem.
ncmike is offline   Reply With Quote
Old 06-26-2014, 07:01 PM   #2
Boog
laying low
Boog's Avatar
Re: 02 Silverado V8 5.3 losing antifreeze
You should have your cooling system pressure tested. They can put in a die to help find the leak.
I just went through this with my 06 crew cab. Mine turned out to be a cracked head. It started losing a small amount then much faster. Keep a check on your oil level. The crack in mine sent the coolant directly into the crankcase. Normally you would associate a cracked head with an overheated engine. Mine had never been overheated in the 3 years we owned it.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-27-2014, 12:29 AM   #3
stepside67
stepside67's Avatar
I had the problem on my 2001 Suburban at 214,000 miles. Initially I only had to add antifreeze once every couple of months and then it started getting much worse. I took it to a shop and they ran pressure test and found the pressure dropping very quickly and no outward signs of leakage. Next step they pulled valve cover on drivers side and you could clearly see the antifreeze leaking from the top side of the head. A set of fully rebuilt heads installed with all the needed gaskets, new head blots, plugs, etc.. was around $2400.00 with a 2yr/24,000 warranty. I was able to catch it early enough and there was not any sludge buildup from the oil/antifreeze or damage to the engine.
I would not add any type of stop leak as this could introduce new problems...A good shop should be able to diagnose this pretty quickly and determine if the heads are the problem. You can google 'CASTEC' and get plenty of information on this topic.
I would also check the water pump gasket and the heater hose quick connects for leaks. Both of these are very common for the 5.3
Stepside67
2016 Silverado LTZ Crew Cab
2001 Suburban
2000 Sportside Reg Cab 4.8 (Stolen)
1967 SWB Stepside Project
stepside67 is offline   Reply With Quote
Old 06-28-2014, 09:32 AM   #4
T3AMCH3VY
Look closely around the heater hose couplers on the firewall. Its a common spot that is easily overlooked. Plus at the rate you are losing coolant you might just see residue from the leak.
T3AMCH3VY is offline   Reply With Quote
Old 07-06-2014, 08:19 PM   #5
Leinie
Don't forget to check the hose on the bottom of the overflow tank. My last two trucks had that hoes start to crack and drain coolant from the tank even though the radiator level remained constant.
Also, intake manifold gasket leaks are common.
Leinie is offline   Reply With Quote
