trouble with door lock please help
my door closes fine the key turns but not all the way unless i push on the door has anyone ever had this problem btw im in reassembly so all new weather stripping and its soft seal so i dont think its the problem seems to me like the latch is binding but duno for sure any help would be great
Re: trouble with door lock please help
Why don't you take the door panel off so you can see what's going on inside when the key gets turned.
project: "my happy mess" |
the panel is off and there is no window in i cant see what is going on the lock mech goes up and down but not all the way unless i push on the door and take pressure off the latch
just hoping someone had same issue and fix cause im stumped
I'm pretty sure it isn't supposed to do that ever, is this an original or aftermarket mechanism?
If it's aftermarket it's possible you just got a defective mechanism, it happens. If it's original it's plum worn out, that happens too. |
#6 | |
You might reach out to LockDoc on the the forum. Leon is very knowledgeable about all things lock and key.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
member #16
![]() Join Date: Dec 1999
A new latch will cure the problem, after forty five years of use there is some wear in the latch.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
#8 | |
The Older Generation
LockDoc
40 year old weatherstripping probably wasn't enough force to hold the striker against the latch in such a way as to prevent turning the key. With new weatherstripping, it is.
So likely its a combination of a worn latch and new weatherstripping. I'd do what other suggested above (repair or replace the latch) and move the striker outwards a little, so long as it doesn't mess up your door alignment (door sticking out too far).
thanks guys i looked into latches im going to order new ones there cheap enough
