Old 06-27-2014, 01:03 AM   #1
birdistheword
birdistheword's Avatar
Trying to decide on how much to drop.
I've never had or lowered a truck before and this is also my first short bed. I want to lower the truck a little and have a little bit of a rake to it. I don't want to bag it or anything crazy. I have a set of 15x7 slotted mags for it and picking up some 15x9s for the rear this weekend. I was thinking of using a 255/60/15 up front and 275/60/15 in the rear. The first pic is how it sits now bone stock. The second pic is of a board member's truck kinda how I would like mine to sit. I'm just not sure if a 2/4 drop would be enough or would I have to do something else?
Erik
1969 Chevy K20 6.0L/4L80E/NP205
1971 Chevy C30 Cheyenne Longhorn 454/TH400
1971 GMC C3500 becoming a K3500 dually
birdistheword is offline   Reply With Quote
Old 06-27-2014, 01:21 AM   #2
67ctener
67ctener's Avatar
Re: Trying to decide on how much to drop.
My guess is your looking about 2/3 drop if your want a little rake. Typically if your looking for level your 2-3" lower in the rear then the front. Most popular static drop here is the 4/6 ece kit. You can use the search and I'm pretty sure there is a whole thread on that kit. Hope this helps
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 06-27-2014, 01:23 AM   #3
67ctener
67ctener's Avatar
I would say this is about a 3/5
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
Old 06-27-2014, 09:44 AM   #4
lannyhaas
lannyhaas's Avatar
Ive got 2" dropped spindels 2'' dropped springs in the front, and 5 inch rear drop, (springs) with a new CPP center crossmember to line up the rear
end. (pinion angle) and swaybars front and rear.
lannyhaas is offline   Reply With Quote
Old 06-27-2014, 11:04 AM   #5
birdistheword
Ok thanks for the info Scott.
Erik
Old 06-27-2014, 09:33 PM   #6
502ms
502ms's Avatar
Make sure to measure your truck's height now. Then factor in that your springs are 40+ years old. Then figure that the new springs will probably sit higher than what's on there now. In other words, it might sit at what a 2/4 drop looks like, and when you put 2/4 springs on, it looks more like a 1/2 drop.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
