Oilfield Trash
Crew Cab Rocker Panel Options
Just picked up an 87 crew cab, needs rockers, just wondering if anybody knows of a full rocker panel instead of the slip on that lmc sells? Or is it a better option just to get 4 regular cab rockers and modify the back ones to fit?
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
Re: Crew Cab Rocker Panel Options
I just modified a front one to fit the rear of mine.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
Oilfield Trash
What did you use for an adapter between the 4500 and 205?
Any info on the modification for the rockers
Long live SLIM ------------------ At least try to buy American ![]() |
post 10 of my build thread shows a pic of the rocker, I basically just cut it up and used the outer skin, you can see it in raw metal in the pic.
the nv4500 has a chevy output and extension housing, and a advance adapters 2" spacer, and bolts right to the 88 205. made a bracket to use the stock 205 shifter as well. you can see the spacer in post 1 or 2 of my build.
