Old 06-27-2014, 07:25 PM   #1
Mr.Hyde
Engine compartment
Ok so I just bought some por15 for my engine compartment so basically protect everything and it deals with a lot of my painting. My question is can this stuff be applied over scuffed paint? Will it last under there due to no sunlight? Or will it bed a top coat? Has anyone done this before?
1968 Chevy C10 build - http://67-72chevytrucks.com/vboard/s...d.php?t=546713
Member of tailgate association of manitoba
Mr.Hyde is offline   Reply With Quote
Old 06-27-2014, 07:48 PM   #2
jlaird
jlaird's Avatar
Re: Engine compartment
Here you go:
CAN I APPLY POR-15 OVER OTHER PAINTS?
Yes, but you will lose the important benefits of POR-15. You must remember that ordinary paints are weakened by exposure to moisture. POR-15 can't stop rust if it isn't in direct contact with the base metal.
MUST I PAINT OVER POR-15 TO MAKE IT LAST?
No, but POR-15 has an ultra-violet sensitivity and must be topcoated if continually exposed to sunlight. Once topcoated, POR-15 will remain effective for many years.
WILL THE SUN DESTROY MY POR-15 COATING IF I DON'T TOPCOAT IT?
If the surface is exposed to the sun for an extended amount of time, the UV rays will eventually break down the POR-15 and cause it to fail. That?s why we recommend you topcoat it.
Take a look at these FAQ's
jlaird is offline   Reply With Quote
Old 06-27-2014, 07:54 PM   #3
Mr.Hyde
I looked through those but personal experience is what I was after. But it any case it seams to me that it's strip as best as you can then apply. Does this stuff go on as smooth with a brush, does it level out?
Old 06-27-2014, 08:22 PM   #4
jlaird
jlaird's Avatar
Yes, it does level out very well and hides any brush marks. If you have time, experiment a little with it...paint a scrap piece of metal to make sure you get your desired results.
Old 06-27-2014, 10:39 PM   #5
Mr.Hyde
Perfect I will try that, I even have some rust scrap with paint. Just to see how durable it is with that approach.
