The Older Generation
Original style brass block fitting for oil pressure line
I have a few new fittings that screw into the oil pressure port on the GM blocks. It’s for the 1/8” line that goes to the oil pressure gauge. These fittings will fit the original GM oil pressure lines with the compression sleeve nuts on them. They are $5 each shipped. PayPal or Money Order works for me. Per board rules post in thread before sending any PM's Thanks, LockDoc
![]() Join Date: Nov 2012
Re: Original style brass block fitting for oil pressure line
PM sent.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
LocDoc
Do you still have any of those fittings ? Thanks |
Yes I do.... PM sent. LockDoc
![]() Join Date: Sep 2007
do i need this to run an original oil guage to an ls motor?
1967custom |
#7 | |
http://www.summitracing.com/parts/ATM-2268/ to screw into your LS block where the original oil sender is or you can break the plastic off of the electric oil sender that's in it and drill and tap it to 1/8" NPT thread. Then screw this fitting in. LockDoc
#8 | |
1967custom |
![]() Join Date: Jan 2013
If you have 2 left i'll take them. Jamie71
I would like to purchase one of those little jewels..I have pay pal ...thanks
I would also be interested in one if you have any left.
72 Ochre Blazer 69 Camaro Z28 Garnet Red 48 Willys (rolled) |
#13 |
I'll take on also.
#14 |
LockDoc, you still have some of these left, I need one. Thanks.
#15 |
PM sent.
LockDoc
#16 |
Lock Doc..do you 2 of the fittings available
#17 |
![]() Join Date: Aug 2012
I'll take 1 if still available.
Thanks |
#18 |
Which fittings do you mean? Block adapter, line fittings, or complete lines.
PM sent.... Thanks, LockDoc
#19 |
My apologies...2 of the block adapter fittings.
#20 |
Yes I do. PM sent.... LockDoc
#21 |
![]() Join Date: Oct 2022
LocDoc, do you have any of the complete oil pressure kits left? I sure could use one!
