Old 06-27-2014, 09:59 PM   #1
DMO
removing lower ball joint
66 c10- I'm in the process of converting to disc breaks and dropping the front end. I have the old spindle out but I'm having difficulty removing the lower ball joint.
Who has advice on the easiest way to remove the ball joint?
Thanks!
DMO is offline   Reply With Quote
Old 06-27-2014, 10:55 PM   #2
sixTsix
Re: removing lower ball joint
get to your nearest orileys or autozone and rent a balljoint press. that's what I did. wasn't bad at all
66' Short Stepper- 350-NP440/4speed
Under Construction - http://67-72chevytrucks.com/vboard/s...d.php?t=629426
sixTsix is offline   Reply With Quote
Old 06-27-2014, 11:02 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Yeah, what he said.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-27-2014, 11:08 PM   #4
Lugnutz65
Lugnutz65's Avatar
Thanks!
Your local auto parts store will probably have a loaner tool section. You will need an air compressor and a 1/2" drive Impact wrench. The ball joint is a press fit. YouTube has several videos showing the process.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 06-27-2014, 11:21 PM   #5
sixTsix
I didn't go the impact route. I did have a second set of hands to hold the LCA ( because the LCA's were off the truck) while I used a larger cresent wrench to run the tool. The impact would be the easiest route if you have the set up
Old 06-28-2014, 12:30 AM   #6
donthekawguy
donthekawguy's Avatar
i JUST DID MINE FOR THE FIRST TIME WITH THE TOOL FROM oRIELLYS. oNCE YOU GET THE TOOL FIGURED OUT IT'S EASY. pUTTING THE NEW ONE IN IT GOT A LITTLE CROOKED BUT i CAUGHT IT IN TIME AND JUST OFFSET THE TOOL A LITTLE AND IT WENT IN. Sorry about the caps
66 shorty
donthekawguy is offline   Reply With Quote
