Old 06-27-2014, 10:33 PM   #1
67gmcturtle
My 67 headlights
I'm working on my 67 and the outside lights work good and when you kick the dimmer switch in the floor the middle lights both come on and my passenger side both lights are on and my driver side the outside light goes off can anyone tell me what might be wrong I'm learning everyday the simple stuff just screws me all up
67gmcturtle is offline   Reply With Quote
Old 06-27-2014, 10:34 PM   #2
67gmcturtle
Re: My 67 headlights
Another pic
Old 06-28-2014, 01:41 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
The inner lamps are high-beam only.... the outer ones have both high and low beams. Your drivers side high beam might just have a bad filament (burned out sealed beam). Or it could be a bad connector, or a wiring problem.
Make sure all connections are clean & snug and no wires are broken. Do you have a test light or a voltmeter? Easiest place to start is to check if there's 12VDC at the connector on the back of the lamp. If not, there's a wiring problem. If you have voltage, wiggle the connector and see if the lamp comes on. If not, it's probably a bad headlamp unit. Swap with your good one from the passengers side to verify it.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 06-28-2014, 09:42 AM   #4
67gmcturtle
Awsome thanks man I'll try that everyone on here is very helpful I'm learning a freeking bunch reading everybody's threads
Old 06-28-2014, 11:53 AM   #5
michael bustamante
michael bustamante's Avatar
Also check your grounds. One might have corrosion
1967custom
michael bustamante is offline   Reply With Quote
Old 06-28-2014, 12:54 PM   #6
67gmcturtle
I'll do that to
Old 06-28-2014, 06:06 PM   #7
bennetth27
Ok I have a 70 stepside I only have 2 lights the dims worked but when I hit the dimmer switch for brights they went out completely so I took the dimmer out and found I had 1 wire shorting out on the bottom of the connecter this could be your problem
bennetth27 is offline   Reply With Quote
