06-27-2014, 10:51 PM | #1 |
Bag length at ride height
I just bagged the front with this kit http://www.airassisted.ca/osc/full-s...5731sije9cgpl4 The bottom cup is about 3" tall and I thought it look a little too tall for the ride height I was wanting. So I put it in always before I started cutting anything, and these photos are at ride height which is around 58-60psi with dominator 2600 bags. If I'm not mistaken shouldn't the bags be longer at this height considering I'm also running 2.5" drop spindles? Could anyone with a similar setup post pics of your bags at ride height? thanks.
06-28-2014, 12:10 PM | #2 |
Re: Bag length at ride height
How tall are the bags @ the trucks ride height/60psi? Most 2600's would prob spec around 5-5.5" tall @ ride height. A good way to tell is measure the bag w/no air in it just sitting on the floor naturally expanded. Ride height should be close to that.
