Old 06-28-2014, 02:33 PM   #1
davepl
davepl's Avatar
Correct shift knob available on eBay
Not mine, but I spent about 3 hours restoring mine yesterday only to find out that someone is selling what looks like proper ones on ebay:
http://www.ebay.com/itm/71-72-Chevy-...c75c14&vxp=mtr
The ones you would get from LMC are the mid-70s Monte Carlo thing (like the Help! packages in the auto parts store).
From the threads I found about the knob here before restoring mine people said there's no way to get it off without destroying it. Here's how I did it:
Leather glove
Rubber glove over leather glove (for traction)
Heat gun
Mount other end in vice. Try to keep it to the non-chrome area otherwise you'll see your vice marks later.
Heat up shift knob as much as you can WITHOUT ruining it. It's plastic, so don't get carried away.
Grab and pull. First time I saw a little gap open up so I just kept at it and it came off fairly easy.
Don't both trying to rotate as you pull, the shaft is splined.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-28-2014, 02:49 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Correct shift knob available on eBay
I got the correct knob a couple years ago from Classic Industries. You just need to order the one specified for 1971-1972. Their part #CX1797. It appears to be the same as the eBay knob in their picture. I think these are marginally different from the originals, but very, very close. The texture at the end seems to wrap around the end a bit more.
FirstOwner69 is offline   Reply With Quote
Old 06-28-2014, 02:54 PM   #3
davepl
davepl's Avatar
Mine is definitely a 70 truck, though I suppose it could have been replaced at some point. More likely the catalogs have the years wrong.
Old 06-28-2014, 05:59 PM   #4
FirstOwner69
All original trucks I've seen had this style knob. I can't say for sure that the splines and means of retention are the same from year to year or for tilt vs. non-tilt. After I posted above, I realized that I'd used this knob on one of my 71/72 tilt columns, but outwardly it looks just like the original on my 69 column as well as the other years. The van and RV tilts that I've seen also used this knob.
Old 06-29-2014, 01:39 PM   #5
too much stuff
Roadtrip!
too much stuff's Avatar
I haven't tried it, but i hear boiling water will work to pull the knob off.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
