![]() Join Date: Feb 2003
Fuel pump problem
My neighbor and I just replaced the fuel pump on my 83 dually. Now I'm not getting any gas to the carb. Other than another fuel pump, what could be wrong and how to fix?
Re: Fuel pump problem
is it a elc pump or manual if manual did you get the plunger under the rod
Just here to tinker
![]() Join Date: Jun 2008
Agree with above, also do you have dual tanks and which tank is selected? Hen the switch fails, it defaults to passenger tank.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
#4 | |
I have recently been having issues with the switch failing and not defaulting to either tank, just kinda in limbo. this has happened to me several times before, unplug the switch from the harness and jump it with a paperclip or a spare fuse to see if you can hear the solenoid under the cab doing its thing. otherwise check your fuses.
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
Salty Sailor
assuming you installed it correctly. maybe the line is clogged.
is your fuel filter before or after the pump? either way replace it. always a good idea to replace the pump and filter at the same time. do you have dual tanks? various components can fail in this system have you checked the condition of the rubber lines between hard lines? could be dryrotted and letting air in causing a loss of suction. a tell tale sign is the strong smell of fuel. good luck
86 c-10 Custom Deluxe Savannah, Georgia |
We just pulled the pump back off and the rod was stuck in the upper position. Removed the upper bolt on the front of the block and got the rod to drop. Need to get the rod up another eighth of an inch to get the pump to seat up against the block. I added some grease to the cavity before we installed the new pump and I wander if I got to much in there. Would the grease around the rod be causing enough suction to keep it from going up the rest of the way?
Fellers, thanks for the other info. If rod doesn't solve the problem, I'll look at some of the other issues. |
possible grease would make it hydraulic not a good thing to use
My 73' 's fuel pump blew by the weep hole so I replaced the stock AC/Delco with a replacement from O'Reily AP and then I had problems at operating temps. I then went with an AC/Delco and now have no problems at all when high vacuum is applied. Just my experience. Some times the oem recommendations are the way to go instead of the cheap replacements.
2008 Chevy Tahoe 4x4 LTZ 2008 BMW 528i 1973 Chevy Cheyenne K10 4x4 |
#9 | |
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Yep. You're on the lobe that pushes the rod down. Bump engine so the cam turns and the rod will go higher.
78K & 79C Jimmys
stock carb?
mine was fuel starved from the backflow valve in the fram filter coming out. http://67-72chevytrucks.com/vboard/s...d.php?t=579621
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Yes, it's a stock carb. We'll try bumping the engine again.
Thanks. |
#13 |
Make sure the rod is being pushed down far enough. Could be the lobe on the cam is worn and not stroking the lever on the pump far enough to pump fuel.
