Old 06-29-2014, 06:11 PM   #1
1971C10Blown
1971C10Blown's Avatar
suspension idea
well i just got a 70 C10swb truck as a new project. my last one was a 96 z28 camaro lt1 6speed. i did lots of work to her but the body and interior were pretty much shot (money went to motor and suspension parts). so instead of getting rid of all the good parts i was thinking of doing a custom rear suspension on the truck. and put a camaro torque arm suspension on it. got all brand new parts to start with including coilover shocks. just wondering what you guys think of this idea. i think it should work pretty good and ride nice with the stuff i have and sorta be one of a kind. the truck right now has leafs a 327 and th350. going to have torque arm suspension 383LT1 and t56. also 12 bolt moser with 4.10 gears.
Jared
2014 Ram 2500 powerwagon
2006 GSXR 600
2012 Arcticcat proclimb 800
1970 C10 SWB 5.3LS turbo and 4L60E
"all throttle no bottle"
"Nitrous is like a hot chick with an STD, you wana hit it but afraid of the consequences"
"its not turbo lag, its for play"
1971C10Blown is offline   Reply With Quote
Old 06-29-2014, 07:56 PM   #2
Ziegelsteinfaust
Re: suspension idea
From what I know of the torque arm suspension is that you will either have to lengthen the torque arm to match the wheel base or shorten the wheel base to match the torque arm.
The pivot of the torque arm is supposed to match the pivot of your U-joint off the transmission. You probably could use a 2 piece shaft to easily give you the extra length you need.
It is a good set-up, but has swap limitations.
Ziegelsteinfaust is offline   Reply With Quote
Old 06-30-2014, 09:50 AM   #3
1971C10Blown
Re: suspension idea
i know there is going to be some fab and thats another reason to do it. its going to be my winter project. i want to do the motor swap soon and get that out of the way and drive it a bit this summer then work on it all winter and do a couple more custom touches to the truck.
Jared
2006 GSXR 600
Old 06-30-2014, 12:50 PM   #4
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: suspension idea
Check out this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=589967
TCI is developing a torque arm rear suspension for these trucks....
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-01-2014, 03:58 AM   #5
andrewmp6
Re: suspension idea
Take a look at http://www.jakesrodshop.com/Products.html he has a weld in torque arm kit for the 1st and 2nd gen f body.With some fab and tweaking it could work for you.
andrewmp6 is offline   Reply With Quote
Old 07-01-2014, 11:06 AM   #6
1971C10Blown
Re: suspension idea
i got all the suspension parts already. just have to mod then up to make them fit the truck.
Jared
2006 GSXR 600
