Old 06-29-2014, 07:54 PM   #1
JointTech
JointTech's Avatar
where did you mount your electric fan relay
theres more room on the drivers side of the coresupport but then I have to run wires across the rad. I was thinking below the battery box but then I remembered the inner fenders are pretty close there.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 06-29-2014, 08:48 PM   #2
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: where did you mount your electric fan relay
I mounted mine below the battery. It fits fine.
Tom Vogel is offline   Reply With Quote
Old 06-29-2014, 11:47 PM   #3
Lattimer
Lattimer's Avatar
I put mine on the fender just back from the battery on the passenger side. Not a show truck, so it didn't matter if i could see them, and easy to get to.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 06-30-2014, 12:14 PM   #4
RManson
Mounted mine on the fan shroud.
RManson is offline   Reply With Quote
Old 06-30-2014, 01:34 PM   #5
mcbassin
Still Learning
mcbassin's Avatar
I mounted mine behind the glove box along with my vintage air relays. I had to run a bunch of wires but it worked out good. Mine has low 3 relays.
mcbassin is offline   Reply With Quote
Old 06-30-2014, 05:13 PM   #6
JointTech
JointTech's Avatar
i went ahead and mounted it under the battery box. Ill get some pics tonight.
72 C20 Long Bed
Old 07-01-2014, 06:31 AM   #7
JointTech
JointTech's Avatar
looks like a rats nest anyway...
put the headlight relays behind the battery while I was playing with fun wires...
sneaked it behind the rad.
72 C20 Long Bed
