06-29-2014, 09:12 PM | #1 |
JBWeld on brass?
It's actually SteelStik, but same idea. In this case its a two-part putty you combine and it hardens to some weird machinable metal.
Anyway, I apparently have a pinhole leak on the neck of my brand new LMC radiator, which is probably our of warranty since it's been more than a year anyway. That's the problem with long builds... So I used some of the putty, but when removing the paint it reminded me that I was working with brass. Anyone know if I should expect it to work and hold? Thanks, Dave
06-29-2014, 09:14 PM | #2 |
Re: JBWeld on brass?
I have done it and it works. It always seems to eventually fail though. On a build as good as yours, I am of the opinion that you should fix it right (solder).
06-29-2014, 09:35 PM | #3 |
Re: J B Weld on brass?
JMHO, but I would rather use a band aid to fix metal than J.B. Weld (N.O. Held). That JUNK has NEVER held anything I ever repaired with it, including a hole in the plastic radiator on my old S10. Might as well use bubble gum because it will hold better. But seriously, I would take it to a welding shop and have them braze the hole over with melted brass.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
06-29-2014, 09:41 PM | #4 |
Cluster King
Clean it like a surgeon and solder it. Paint and call it good.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
