Old 06-29-2014, 11:21 PM   #1
Damien
Damien's Avatar
74 Blazer ignition circuit always hot
My 74 Blazer keeps blowing the ignition fuse. The circuit is hot with the key off. The truck has been converted to HEI. The ignition swith and neutral safety switch are new. I disconnected both and still have power with the key off. I tried a different starter solenoid I'veand disconnected the pigtail from the alternator. I've taken the harness off the firewall and have power to a red 10 gauge wire. I have not started pulling the harness apart yet. Any ideas were to look now?
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 07-03-2014, 06:06 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: 74 Blazer ignition circuit always hot
Not exactly sure what you mean. The ignition switch will have a constant hot to supply power to it. If it is keeping the ignition system hot then you would have to unplug the distributor wire to shut off the truck. Can you shut off the engine with the key?
Just call me Sean is offline   Reply With Quote
Old 07-03-2014, 07:14 PM   #3
willett
Another Day, Another Dollar
willett's Avatar
It sounds like he's getting constant acc power.
If that's the case I would start at the switch.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 07-04-2014, 01:35 PM   #4
Damien
Damien's Avatar
The fuse blows as soon as i put it in, even with the key in the off position. I ran the distributor wire directly to the hot side of the fuse holder to start the truck. The wire had to be disconnected to turn the engine off. It sounds like i need to check the wire locations on the ignition switch.
