Old 06-30-2014, 08:39 AM   #1
bigd65
bigd65's Avatar
seam to be losing AIR
just fixed the air door that little plastic piece breaks on. Well I fixed it with a little piece of metal bracket and it opens and closes now. Still dont get much air through the vents after putting the all the vents back. and barely get any air through the defroster vents...... come out strong through the flor vent though
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 06-30-2014, 08:48 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: seam to be losing AIR
sounds like somethings come loose
defrost and dash vents should be off
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-30-2014, 07:53 PM   #3
bigd65
bigd65's Avatar
Ok I got something that is messed up. I did notice that (truck running) I put it on MAX AC and the vent on the passenger kick panel opened up. I figured MAX would be all inside air..... I think the PO messed something up when the heater core was changed. I have not had it out at all
2017 Chevy Tahoe
Old 06-30-2014, 10:57 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
I'd check the lines are right then
John
Old 07-01-2014, 08:20 AM   #5
bigd65
bigd65's Avatar
yea, now I just gotta make the time for that
2017 Chevy Tahoe
Old 07-01-2014, 08:59 AM   #6
v30crewcab
v30crewcab's Avatar
yes the pass vent opens up, and the one in the cowl by the pass wiper closes, so it recirculates the air.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 07-01-2014, 10:40 AM   #7
bigd65
bigd65's Avatar
so its suppose to open on MAX AC ?????
2017 Chevy Tahoe
Old 07-01-2014, 11:17 AM   #8
v30crewcab
v30crewcab's Avatar
yes.
71 longbed 5.3 4l80
Old 07-01-2014, 11:39 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
No they both close.
Cowel and kick panel.
John
Old 07-01-2014, 03:24 PM   #10
bigd65
bigd65's Avatar
for that matter, why would the kick panel open at all with the AC ON in either position. that lets in outside AIR that is not circulated across the condenser
2017 Chevy Tahoe
Old 07-01-2014, 03:47 PM   #11
Jonboy
Slots go on anything!
It pulls the cooled air across the evaporator coil (behind the dash). The kick panel vent is only open at the top. When the upper flap closes, the blower motor recirculates the inside air.
You might want to pull the ducting and reseal it. That might help out as well.
1974 Jimmy- 5.3/4L80e/NP241
Old 07-01-2014, 08:52 PM   #12
bigd65
bigd65's Avatar
I think I'm going to pull the whole thing. See if the all the actuators are working. Can't get much air through the defroster vents.... Might be backwards.... Knowing the previous stuff I have had to straighten out
2017 Chevy Tahoe
Old 07-01-2014, 10:03 PM   #13
v30crewcab
v30crewcab's Avatar
the kick panel vent opens so the fan can pull the air from the cab back thru on max, at the same time, the cowl vent thats normally open, so you get fresh air, closes so all you get is recirculating air.
71 longbed 5.3 4l80
Old 07-01-2014, 10:39 PM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
Something else,
The actuator floor/defrost has three holes.
I use the middle, all up or down.
But some are made to leave some up or down all the time.
John
Old 07-02-2014, 07:44 AM   #15
bigd65
bigd65's Avatar
Crew cab , that makes sense.....
Motor nut , I get VERY LITTLE air through the defroster duct when on DEFROST.... I get a lot of air on the floor when on heat....
2017 Chevy Tahoe
