Old 06-30-2014, 11:52 AM   #1
jd21476
jd21476's Avatar
4WD popping out of gear
I was towing my jet ski this weekend and it was runnign fine until we got off hte highway. Then all of a sudden I lost all gears. Turns out my transfer case had popped into neutral. I put back in 2WD High and started down the road but as soon as I let off the gas it popped into neutral again. I put back in 2H only to have it do it again.
I wound up driving to the lake while holding the 4WD shift lever in one had to make sure it did not pop out.
Spent the day on the lake and drve home and it never popped out of gear again. My truck is a '73, 350, 700R4 automatic.
Any ideas?
1973 Chevy K20
jd21476 is offline   Reply With Quote
Old 06-30-2014, 12:45 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 4WD popping out of gear
What transfer case do you have behind that 700R4 ?
Old 06-30-2014, 12:53 PM   #3
jd21476
jd21476's Avatar
Not sure but I just called my tranny guy at CDO Trans (the guy who swapped my TH350 to the 700 R4) and he is going to check it out for me. He said it coudl be a mount.
1973 Chevy K20
Old 07-01-2014, 03:16 AM   #4
andrewmp6
If you take a few pictures of the t case we can id it,Or look for a tag on it will say np and some numbers.
andrewmp6 is offline   Reply With Quote
Old 07-02-2014, 11:01 PM   #5
hrc200x
Its probably a 208 t-case, sounds like the same issue I had with a truck at work back in 2005 or so, it was a 400/208, doing down road at 55mph and it went into a neutral, if I recall the shifter didn't move though. 2wd and 4hi worked sometimes but would pop out. 4lo was the only gear that it would stay in. I believe its from worn internals in the tcase, shift forks or something. Hopefully your issue is somthing else. I ended up buying this truck from the place I work and to this day am still using it for plowing...tcase was never apart to fix it but I do two driveways and use 4hi and it stays in so far.
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208.
hrc200x is offline   Reply With Quote
