Old 06-30-2014, 01:08 PM   #1
monte0185
monte0185's Avatar
86-91 Grille Swap questions
Got a couple questions about this swap. Guess id better start with I have an 86 Crew Cab dually. I got a 90 model suburban front clip. Radiator support forward. The hardware is a pretty simple swap but I have wiring questions. Ive read a few threads where they just swapped pins at the bulhead connector to fit and wired the dark blues together but that to me still has the issue with all the power going thru the switch to the relays. I already have the relay conversion harness on mine. Has anyone converted the relay harness over to fit the new style bulb or is there something better to do. I only got part of the harness since I didnt pull it myself but i know where another harness is I can grab if I need to. Suggestions please.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 06-30-2014, 09:58 PM   #2
83GMCK2500
Re: 86-91 Grille Swap questions
Is your '86 originally a dual lamp front or a single lamp front? Depending on what you have the answer varies.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 06-30-2014, 10:09 PM   #3
monte0185
monte0185's Avatar
Its a dual lamp with the original harness intact and the relay harness added.
Old 07-01-2014, 12:27 PM   #4
monte0185
monte0185's Avatar
For Future FYI ers. this place has the correct color coded conectors for the 4701 and 4703 headlights. I ordered 2 of each and Im just going to retrofit my relay harness with them. Should be much simpler than building a whole new harness although not as fun.
http://www.repairconnector.com/produ...Connector.html
http://www.repairconnector.com/produ...r-Pigtail.html
Old 07-01-2014, 03:47 PM   #5
83GMCK2500
Sorry for the delay...that is EXACTLY what I was going to suggest for you, swapping the plugs on your existing relay harness. If you had the single lamps it would've been more of a hassle, but with your existing dual lamps and harness it's a simple plug swap. Thanks for those links.
Devin
New Daily, the '96
Old 07-01-2014, 04:09 PM   #6
monte0185
monte0185's Avatar
Thats what I figured but what was baffling me was why no one makes a relay harness for these Setups. I had considered that maybe by these years they had already converted to relays but couldnt find any info on that either. Needless to say other than converting the original harness to the old plug for the firewall there is not alot of info on this swap. Im still considering grabbing another harness off a donor truck and making me a relay harness out of it so all the marker lights and turn signal plugs are in the correct locations and I like playing with that Kind of stuff. Who knows maybe there is a market for a conversion harness thats Plug and Pray. LOL
Old 07-01-2014, 10:07 PM   #7
v30crewcab
v30crewcab's Avatar
lmc carries the relay harness for those frontends, but it only works with the upgraded headlights they sell that take the little bulbs in the back.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
