Old 06-30-2014, 02:33 PM   #1
67 chevelle
67 chevelle's Avatar
67 c 10 no front sway bar
I have been working on a 67 , cutting the bed , lowered the rear 2 inches , while I was back there , I decided to put a rear sway bar in . Im running 31 x 10 1/2 x 15 tires so figured it would help with handling . I got the cpp kit , when I was finished there I decided to check the front to see if the bushings were shot ,,, no bar , there never was one . Is this common ? I thought they all had front bars .
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 06-30-2014, 03:04 PM   #2
trac209
Re: 67 c 10 no front sway bar
My 68 has no bar and never did. It's on my to do list though
trac209 is offline   Reply With Quote
Old 06-30-2014, 03:57 PM   #3
cdowns
cdowns's Avatar
was optional from factory
Old 06-30-2014, 04:23 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
You can use the bar and brackets from 73-87 style trucks. 1 tons had the largest. The large brackets are riveted to the frame. I usually pull the bar in the wrecking yard but leave the frame bracket. I bought new lower profile brackets for lowered trucks from cpp. Iirc they were around $25.
WIDESIDE72 is offline   Reply With Quote
Old 06-30-2014, 05:52 PM   #5
67 chevelle
I got the front cpp kit , surprisingly it came quick and was reasonable , its huge , biggest bar Ive ever seen , and went in easily , hardest part was removing the rivets to the radiator support , they get replaced with bolts and a bracket
