Old 06-30-2014, 02:39 PM   #1
serge
serge's Avatar
Want to see the lights (better)
Dash lights not very bright. Just replaced all the bulbs and no change in brightness.
Is it possible the dimmer is faulty?
Serge
serge is offline   Reply With Quote
Old 06-30-2014, 03:15 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Want to see the lights (better)
Possibly, or it could be poor connection(s) or bad ground(s). Check voltage with a digital VOM, and check grounds (referenced to a known good 12VDC source) the same way.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 06-30-2014, 03:20 PM   #3
hamjet
hamjet's Avatar
Alot of people are switching from 194s to 168s, they say they're alot brighter..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 06-30-2014, 03:24 PM   #4
davepl
davepl's Avatar
I switched all of mine to LED (194 direct replacements). Only downside is the ones I chose are a "daylight" color that is too blue for me.
I noted that my tach is a lot brighter than the others. Then I also found that the tach actually takes a different bulb (maybe its a 194 vs 168 thing) that I have to look into.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-02-2014, 01:57 PM   #5
serge
serge's Avatar
Thanks for the feedback.
Will check wires and ground. Figure it's good to rule out any issues here.
Bought digital volt meter. Any tips on how to use would be appreciated.
Serge
Old 07-02-2014, 05:22 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Basic voltage checking is pretty straightforward. Depending on your specific VOM, there may be an on/off switch. Some are auto-select but you'll probably need to select DCV and maybe a suitable range, such as up to 20V. Polarity doesn't matter all that much here, but to read it correctly, plug one lead into the COM port and clip (or hold) the end of the probe to a known good ground. The other lead plugs into the Volt/Ohm port -- use its probe to check for voltage.
- Mike -
RIP El Jay
Old 07-04-2014, 12:08 AM   #7
Daner
Daner's Avatar
When I had my cluster out to lube the speedo cable I repainted the backing plate white instead of black. Also painted the back of the housing white instead of that weird green color that the plastic is. It brightened it up tremendously. I think there are some threads on that.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 07-04-2014, 10:36 AM   #8
Hawghauler
Hawghauler's Avatar
On my '67, my dash lights didn't work at all, until I twisted the switch back towards the dome light that did work, and saw a flash of light from the gauges. So I twist it back and forth a number of times, and boom dash lights. I eventually replaced the switch.
If I have to be on 4 wheels, It has to be a classic Chevy
1967 c10 Longbed (Hawghauler/Icy weather transport)
2003 BMW K1200GT (Rain bike)
2007 Softail Deuce (Sun bike)
2009 Ultra Classic Electra Glide (Everything else bike)
Hawghauler is offline   Reply With Quote
Old 07-04-2014, 03:23 PM   #9
davepl
davepl's Avatar
I lined the inside of mine with the 3M metallic duct tape (NOT the cloth 'duck' tape - the real metal foil stuff). That made it effectively all reflective inside and brightened it up.
Did the same with my tail lights.
