What's a 1973 - 1987 C10 1/2 ton rear end going for?
I have a 1985 C20, more specifically a C2500, with an 8-lug, 14-bolt f.f. rear with 4.10 rear gears that I plan on swapping out with a 5-lug rear end. I like the rear I have now. No leaks, look and works great, and pulls like a hos but It's an 8-lug and I'm in process of installing a full Porterbuilt suspension. I want to go to 5-lug for a wider array of wheel options. Thanks, G
![]() /Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat / SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed |
Re: What's a 1973 - 1987 C10 1/2 ton rear end going for
$100.
Oh, did you want to pick the gear ratio? Posi or gov-lock? newer axles? $200 for 3.08 open, 20K rebuild. $800-1200 for fresh rebuild with a posi, your core axle. FYI, the posi and gear and install kit is right around $700, fortunately axle bearings and seals are cheap, axles aren't too bad ($150-300 depending on what you want). Watch CL. I have found no one wants to advertise the 3.08 non-posi axles. Local yards go $150, you pull.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
$50-200 depending on the ratio & if it's a 10-bolt or 12-bolt housing would prob be the CL norm. I sold a bare 12-bolt housing last year to a board member for $75. I've also seen them listed @ 2K by the CL dreamers....
