06-30-2014, 03:13 PM | #1 |
stand alone hardness LS1 Swap ????
Hy all ,
after i blew up my 1.GEN sbc ..i am looking forward to do a LS1 swap.. I want to do the swap into a Chevy Pickup 51 with a camaro subframe 1977. I am from Germany and so i have to get along with the small spare part market here.... So far i do have a used corvette engine available..without brackets / waterpump e.g. Therefore i need a standalone harness + ECM I hope u do have some good sources for these ?? Thanks a lot regards Achim |
06-30-2014, 03:56 PM | #2 |
Re: stand alone hardness LS1 Swap ????
I used a PSI harness. I know they sell the harness and ecm. They also sell the pedal, and TCM module if you are using a dbw tb. They make several different harnesses depending on your needs.
07-01-2014, 11:03 PM | #3 |
Check with bill at bp automotive, you will not be disappointed!
07-02-2014, 12:16 AM | #4 |
I used CBM in southern California, they weren't the cheapest but they offered a 4' extended wiring harness.
07-02-2014, 01:09 AM | #5 |
Howell Engine Development had all of the parts I needed for my swap, .....get in line!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
07-09-2014, 09:23 PM | #6 |
Anyone try Chase Bays? They look nice to me.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel |
07-10-2014, 01:31 PM | #7 |
Ive been using LSX Performance wiring out of Texas, they are on Facebook...but they do some great work around $400 bucks for a harness and i had it in less than a week. Works great and had no issues like Ive seen with other brands of standalone harnesses.
07-12-2014, 07:25 AM | #8 |
that sounds pretty cheap......pls can u send me some contact datas (email) ??
Thanks a lot Achim |
