Old 06-30-2014, 04:55 PM   #1
tll74
"Junkyard Dog"
tll74's Avatar
What color is this 67 C10 seat?
I'm trying to figure out what color this seat is so I can get a new covers. Is it Aqua or metallic green? Those seem to be the two choices that the after market companies offer. It is out of a 67 C10 base model truck. The interior color is light green metallic and the outside is the same as the doors in the pics. Pics courtesy of GCncsuHD. Thanks in advance for any help, Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
Old 06-30-2014, 05:26 PM   #2
Fldawg
Fldawg's Avatar
Re: What color is this 67 C10 seat?
It is Turqouise
Fldawg is offline   Reply With Quote
Old 06-30-2014, 05:57 PM   #3
hamjet
hamjet's Avatar
light green? truck doors appear to be light green...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 07-01-2014, 06:50 PM   #4
A.Bursell
I'm going through the same thing with my '67, same colors in and out except mine has the Custom interior, so slightly different seat but same color.
I have not had much luck with matching it up. I got samples from The Filling Station and it was almost an exact match for Aqua. I ordered the cover and after a month when I called to check status they told me it was discontinued. I see that GMCPauls also has the same color selection but no samples available. I went ahead and ordered Aqua again-- taking a chance-- but it will be about 8 weeks before I see anything they tell me.
Short answer-- I think it is called Aqua in the aftermarket.
Adam
A.Bursell is offline   Reply With Quote
Old 07-01-2014, 07:46 PM   #5
68Gold/white
I had a 67 Bel Air w/ similar interior, exterior was close, paint name was emerald turquoise...
68Gold/white is offline   Reply With Quote
Old 07-02-2014, 10:06 AM   #6
60-66
60-66's Avatar
Had the same seat in my 67, the spid just says green.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 07-02-2014, 11:15 AM   #7
tll74
"Junkyard Dog"
tll74's Avatar
I spoke yesterday with John at Brothers which bought this seat (the one in the pics) from member GCncsuHD. He bought it with hopes to find a source to reproduce it. He says that the color and material is available but no luck on the ability to reproduce the pattern. He says that the color is Aqua. They offer a cover for the 67-68 seat in Aqua but it is a little off in color. That might be the way I go...
Old 07-02-2014, 12:09 PM   #8
sboris
sboris's Avatar
I started with the same seat. Ended up taking to my apolstery guy and got a close match. It might be a touch brighter, but nice. I wanted the factory pattern as well, but like others no luck.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 07-02-2014, 01:16 PM   #9
Chvy2NV
Subd..
Chvy2NV is offline   Reply With Quote
Old 07-02-2014, 03:39 PM   #10
BluTrukker
BOHICA
BluTrukker's Avatar
Same issue here. My 68 has the same color interior with the light green exterior. Nobody seems to have a replacement that is the original color or pattern. I think I am going to have Truckseats do a custom one for me.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig!
BluTrukker is offline   Reply With Quote
Old 07-03-2014, 10:00 PM   #11
That aqua was a common '60s automotive fabric color across the board in the '60s ('50s,too). I'd imagine SMS could come up with an alternative pattern from some other model. When it comes to reproduction trim,for the most part it's the upper level stuff that gets reproduced and the standard stuff is overlooked.
Old 06-19-2019, 09:46 PM   #12
tim_mc
tim_mc's Avatar
For anyone looking for light green/aqua seat alternatives, I had my local upholstery shop sew up a seat cover in Naugahyde Phoenix Dusty Jade (PH46), which I think matches the original seat color the best. The original seat didn't have any cording, so we kept it plain. While we couldn't simulate the fine heat-rolled pattern, the vertical stitches and center panel captures the basic farm truck look. Samples can be requested from Naugahyde direct.
https://www.naugahyde.com/catalog/pa...cfm?iteID=4134
I also chose to go with 3-point seat belts and center lap belt in Turquoise from Seatbeltplanet.com, which is the closest I could get to the seat color and the turquoise steering wheel.
The carpet will likely be ACC 80-20 loop in Turquoise/Aqua (#508) from Stock Interiors. I'll order carpet after welding in the RH cab corner, outer rocker, kickpanel and front pillar/fender mount, hopefully in a few weeks.
Looking forward to getting it assembled this summer.
~Tim
tim_mc is offline   Reply With Quote
Old 06-19-2019, 09:57 PM   #13
Getter-Done
Getter-Done's Avatar
~Tim
Thanks for the info.
And Pictures.
84 Chevy K-20
Old 06-20-2019, 11:29 PM   #14
ThreeQuarter
ThreeQuarter's Avatar
SMS Auto Fabrics says they can get the exact materials for my Custom seat, but those materials would be a little different than the base seat you have. They matched the color very well.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 06-21-2019, 08:23 AM   #15
tim_mc
tim_mc's Avatar
That's going to be a sharp looking seat. Did SMS give any stock or part numbers with those samples? It's too late for me, but that B sample would probably be a good match. My Naugahyde vinyl color is close, but it's not metallic like the original material is.
Old 06-21-2019, 10:16 AM   #16
ThreeQuarter
They don’t give any part/stock numbers, they only give me this sheet and refer to the samples as A, B, and C. If I call them to order something, they have to look up my quote sheet to find what product I’m referring to. I think they do this so they don’t have to reveal the supplier and stock number.
Ben
Old 06-21-2019, 10:22 AM   #17
ThreeQuarter
Tim, I’m glad you posted the pics with the turquoise seatbelts. I have never trusted the seatbelt companies’ online color samples because the color accuracy depends on so many things, and my idea of turquoise is much blue-er than my light green pickup. But your post makes me think it could work. Think I’ll see if I can get a sample of the webbing.
Ben
Old 06-21-2019, 10:40 AM   #18
HO455
Post Whore
HO455's Avatar
~Tim
Good post and welcome aboard! As I near the upholstery stage this is good and timely information. That Dusty Jade looks to be a good choice to go with my not quite factory green.
On your seat belts did they come with the clasps painted and do they have retractors? I got ones for mine with what looks to be the same webbing, but different clasps several years ago. At the time it was all I could find in the turquoise color.
RIP Bob Parks.
Old 06-29-2019, 05:48 PM   #19
tim_mc
tim_mc's Avatar
Sorry for the late reply. Yes, these seat belts have retractors. I'll try to remember to look at the seat belts tomorrow and possibly take a pic or two of the whole assembly. I believe the shoulder anchor bolt cover and retractor cover are black plastic, so they could be painted. Mine have the retractor brackets set up for no fuel tank.
Old 06-29-2019, 09:06 PM   #20
irl104
I got new seat belt material from Seat Belts Plus. They make different weave patterns for different years. Worth checking into for your color you are wanting.
New buckles and tags from In Line Tube.
The seat material is NOS from N.O.S. Automotive Fabric in Columbus, Michigan. It is the original material and exact pattern for my 1968. Tony and I talked on the phone and sent emails back and forth. He sent me pictures of the materials and advised me of measurements that I would need. I highly recommend them if your going back to original.
irl104 is offline   Reply With Quote
