Old 06-30-2014, 07:11 PM   #1
Harleydad
55 TF rear
I am new to this site. I want to change to a 5 lug pattern on the rear of my 55 2nd series. Is there a rear that is a bolt in. NO welding.
Thanks OGRE
Harleydad is offline   Reply With Quote
Old 06-30-2014, 07:55 PM   #2
oldman3
oldman3's Avatar
Re: 55 TF rear
I'm don't know the 55 2nd series that well. Can you give the current wheel mounting surface from side to side (60" - 62", etc) and also the center to center distance on the springs width (43" -45", etc) this info might get a better reply, good luck...Jim
oldman3 is offline   Reply With Quote
Old 06-30-2014, 09:28 PM   #3
fabguy
Elev8r Man
fabguy's Avatar
Re: 55 TF rear
Thanks OGRE
a camaro works very well although you will need to cut and re-weld in the spring perches. There is no real direct BOLT in that I know of.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
Old 06-30-2014, 10:11 PM   #4
Harleydad
Re: 55 TF rear
Do you know if there is a manufacturer that makes replacement axles? Doing most if not all in my driveway. Just until the house sells then i am going to have to find a place.
Old 06-30-2014, 11:59 PM   #5
OrrieG
OrrieG's Avatar
Re: 55 TF rear
Hub to hub may be too much for you but 73-80 something 1/2 ton truck bolt up to the 59 springs. They came in 5 and 6 lug configuration. I run 225-7516 tires on mine to keep the tires under the fleetside fender using stock 16" steel wheels. The 5 lug were 15" wheels.
OrrieG is offline   Reply With Quote
Old 07-01-2014, 01:18 PM   #6
curmudgeon
Re: 55 TF rear
Here is one of the best guides on swaping rears:
http://www.chevytrucks.org/tech/rear_ends.htm
When you say 5-lug, I assume you mean the 5 X 4 3/4" bolt pattern of Chevy cars in which case the Camero is the most commonly used as mentioned
However later 2WD Chevy trucks use a 5 x 5 bolt pattern:
http://67-72chevytrucks.com/vboard/s...d.php?t=234769
so you may not want a later truck rear (which is wider as well) if you are either subframing or IFS the front with the 5 X 4 3/4 pattern.
I use a staggered tire size Front/Rear so technically Ft/Rear bolt circle differences don't matter but I personally just want all 4 corners to match so my spare fits all.
curmudgeon is offline   Reply With Quote
