08-04-2003, 09:14 PM | #1 |
EGR Question
While on a run from Greenville to the Atlanta airport about 150 miles my service engine light came on. It didn't come on until after about an hour of running 75 to 80mph. Truck ran great even with the light on. Same thing happened on the return trip. I replaced the EGR solenoid valve about 6 months ago, had a cracked hose fitting. Wondering about an over active egr valve or maybe O2 sensor. I jumpered the test port and got a 34 (EGR). Doesn't do it on normal driving around town. Any thoughts or help is appreciated.
08-05-2003, 12:52 AM | #2 |
You get what you pay for
I'm not a EFI specialist, but it's possible it could be the EGR solenoid too. I know the code says EGR, but this is a vague code. Anywhere in the EGR circuit could put up a EGR code.
Check all the hoses to make sure they are not broken or cracked. Clear the codes by unhooking the positve battery cable. Pull the plug on the solenoid and see if it sets the same code. Other than this, I wouldn't know what to tell you. I guess you could replace the EGR valve, but you may be spending money on nothing. If it were me, I'd replace the solenoid before replacing the valve.
Mike 1985 Chevy C-10 |
08-05-2003, 09:02 AM | #3 |
Thanks for the advice Mike, I was kind of leaning that way also. Seems to me electronic stuff is more apt to break than simple mechanical things. I really don't like that emissions system. Wish I could trash it but don't want to go to all the expense. Thanks again.
Rusty 87, 350, 700R4 3/5 Drop |
08-07-2003, 06:17 PM | #4 |
LED King
I just got a code 34 and my book says it is the MAP sensor. I just accidently unplugged mine. The MAP sensor is on the passanger side of the firewall at the top just off center. The vaccuum hose is small so if you bump it it will come out of the fitting on the carb.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
08-07-2003, 06:48 PM | #5 |
Fault code
Hey Tyler, your right about the fault code. I looked in my repair book and had marked code 32 not 34, I incorrectly typed the wrong code from memory, should have known better!. You know they say your memory is the second thing to go!! Thanks for the heads up any way.
08-08-2003, 10:13 PM | #6 |
If you get that code then it means it is NOT opening. The ECU see's a change in the O2 and Map when the EGR is open. If it doesn't see that for about a mile when driving steady speed it will throw that light.
It might be the passages are plugged up and causing it and not a problem with the controls. I have seen the port in the intake plug right below the carb in one. Not much different set up on a TBI.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
08-09-2003, 12:00 AM | #7 |
Yeah, when I had the intake off my 87 305 in the van, that thing was caked up pretty bad. But the 305 has quite a few miles on it, so I guess it was time.
